VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
PRNDS lights flashing
Old 08-26-2013, 08:10 AM
Kasim's Avatar
Exclamation PRNDS lights flashing
hi guys,
I have an Audi A4 2.0 FSI SE 4dr Multitronic Saloon 2004 with 44,000 miles. PRNDS lights started flashing the other day and its shifting between D and S, but I didn't loose any power. Diagnostics says:
18201- transmission speed sensor 2 (G196) No Signal P1793
17090 - transmission range sensor (F125) Implausible Signal P0706 Intermittent.
i am bit confused as to what needs to be changed? do I have to change few sensors or whether transmission ECU needs to be replaced? Are sensors located outside the gear box? What kind of cost are we looking at?
I booked an appointment with an Audi dealer but they charge like £135+vat / hour. Ouch!!!!
I found a company in uk that can rebuild ecu for like £250. But I don't know what the problem is and whether rebuilt ecu will work fine as its located, I believe, inside gearbox and its replacement is probably 4-5 hour job.
Any help will be appreciated.
Thanks.
Old 09-05-2013, 11:06 AM
ameenqureshi's Avatar
I may be wrong here. I'm not sure about Multitronic boxes, but if it were a DSG, it sounds like the mechatronics unit is malfunctioning. if you're lucky it's just the control module that can be replaced or flashed. If not that, you need a new mechatronics unit. If it comes to replacing it altogether, then i'd suggest you look for a used part. They tend to be quite steep in pricing.
I'll research on the codes and get back to you though.
Keep us updated.
Kasim
08-26-2013 08:14 AM
Cuda66
07-17-2013 12:20 AM
xiaokai
07-02-2010 03:27 PM
mshprojects
09-01-2008 07:01 PM
prototype821
07-24-2007 09:46 PM
Quick Reply: PRNDS lights flashing
