VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VAG COM Scan - Please Help
Old Dec 5, 2013 | 12:45 PM
stevendsouza's Avatar
Angry VAG COM Scan - Please Help
Team I need help. I just ran a VAG COM scan on my Audi Q7 and this is what I get as the scan results. What's surprising is that there are many modules which show as "cannot be reached" but are functional. E.g. Park Assist, Backup Camera etc.
Also to let you know the only 2 problems that are visible on the Q7 us that the Side Assist Does not work and gives a message "Audi Side Assist System Fault" and Bluetooth gives a message "Phone not installed"
I assume there is some wiring which is loose but don't know where to start looking.
Any help would be appreciated.
__________________________________________________ ___________
Sunday,24,November,2013,21:36:31:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 4L0
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 28 36 37 3C 42 46
47 4F 52 55 56 5C 61 62 65 67 69 6C 6D 6F 72 76 77
VIN: WA1BV74L18D030792
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
0F-Digital Radio -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
6F-Centr. Conv. II -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: Redir Fail!
Part No SW: 4L0 910 560 G HW: 4L0 907 560 B
Component: 4.2l V8/4V 0020
Revision: 78H02--- Serial number:
Coding: 01210009190F0960
Shop #: WSC 31414 790 00001
VCID: 2C5D1A698F10169
2 Faults Found:
000136 - Fuel Rail/System Pressure
P0088 - 001 - Too High - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 1
Mileage: 143873 km
Time Indication: 0
Date: 2013.11.24
Time: 12:57:20
Freeze Frame:
RPM: 910 /min
Load: 37.6 %
Speed: 7.0 km/h
Temperature: 88.0°C
Temperature: 39.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.335 V
P0088 - 004 - Too High - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Mileage: 143873 km
Time Indication: 0
Date: 2013.11.24
Time: 12:57:35
Freeze Frame:
RPM: 703 /min
Load: 33.3 %
Speed: 0.0 km/h
Temperature: 88.0°C
Temperature: 39.0°C
Voltage: 13.335 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 GF HW: 09D 927 750 GF
Component: AL 750 6A 1072
Revision: 00H64000 Serial number:
Coding: 0000504
VCID: 78F5F6390BC86A9
No fault code found.
Address 03: ABS Brakes Labels: 4L0-910-517.clb
Part No SW: 4L0 910 517 B HW: 4L0 614 517 D
Component: ESP ALLRAD MK25E1 0010
Revision: 00H30001
Coding: 0082993
VCID: 2953E37D80E2031
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500907432
Coding: 0000135
VCID: E3CF3155224E191
Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H27 0080
Part No: 4F0 910 220 G
Component: FBSAUDIC6 IDG H01 0060
2 Faults Found:
00193 - Right Rear Door Handle Touch Sensor (G418)
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 3
Fault Frequency: 3
Reset counter: 12
Mileage: 142657 km
Time Indication: 0
Date: 2013.11.16
Time: 14:24:23
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00110111
Fault Priority: 3
Fault Frequency: 6
Reset counter: 54
Mileage: 142657 km
Time Indication: 0
Date: 2013.11.16
Time: 14:24:11
Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
Part No SW: 4L0 910 732 R HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 354JO077530251
Coding: 0002003
VCID: 387536394B48AA9
Part No: 4L0 910 609
Component: E0380 BedienteilH01 0060
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 252
Mileage: 142648 km
Time Indication: 0
Date: 2013.11.16
Time: 14:00:41
Address 08: Auto HVAC Labels: None
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Component: KLIMABETAETIGUNGH05 0060
Revision: 00---012 Serial number: 00000000136958
Coding: 0786472
VCID: E1C33B5D38520B1
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0114123
VCID: 30650E19A338729
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H15 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00152619
Shop #: WSC 31414
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4L0 910 110 B HW: 4L0 035 110
Component: MP3-Changer H45 0390
Revision: 00045006 Serial number: AUZ5ZBG1233705
Shop #: WSC 00000 000 00000
VCID: 1E39C0A1C9ACF49
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 7
Fault Frequency: 1
Reset counter: 252
Mileage: 142648 km
Time Indication: 0
Date: 2013.11.16
Time: 14:01:39
Freeze Frame:
Text: 00000000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7G0177746
Coding: 0000100
VCID: 31630B1DA8327B1
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH42 0230
Revision: 06H42000 Serial number: 0038QD0779B+
Coding: 0014131
VCID: 2B5F19758A1E111
Part No: 4L0 910 339 A
Component: BF-Gewichtsens. H03 0030
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H04000 Serial number: 90055072620097
Coding: 0032242
VCID: 2757E54596F6351
Part No: XXXXXXXXXXX
Component: E0221 H01 0030
Address 17: Instruments
Cannot be reached
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 A HW: 4L0 907 468 C
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1000D078038386
Coding: F7F7FE77767A0200
VCID: 2D5B176DB40A1F1
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 252
Mileage: 142648 km
Time Indication: 0
Date: 2013.11.16
Time: 14:01:50
02103 - Control Module 2 for Vehicle Electrical System (J520)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 43
Mileage: 142818 km
Time Indication: 0
Date: 2013.11.17
Time: 19:15:16
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 B
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 010000
VCID: 2B5F19754A1E111
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000136802
Coding: 0000006
VCID: E8D52679DB687A9
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
1 Fault Found:
01446 - Sensor for Driver Seat; Seatback Adjust (G230)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 43
Mileage: 142648 km
Time Indication: 0
Date: 2013.11.16
Time: 14:00:41
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H50 1100
Revision: 00000000 Serial number: 313JS077527353
Shop #: WSC 44881 000 1048576
Address 3C: Lane Change Labels: None
Part No SW: 4L0 910 566 B HW: 4L0 907 566 A
Component: J0769_SWA_MasterH10 0100
Revision: 00H10000 Serial number: 6PZ 009 014-00
Coding: 0010001
Part No: 4L0 910 568 B
Component: J0770_SWA_Slave_H04 0100
2 Faults Found:
16365 - Control Module - Electrical Error; CPU 2
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 159
Mileage: 64572 km
Time Indication: 0
Date: 2010.06.15
Time: 21:18:15
16358 - Control Module - External RAM Error; CPU 2
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 162
Mileage: 64644 km
Time Indication: 0
Date: 2010.06.16
Time: 20:44:25
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0150
Revision: 00000000 Serial number: ˜
Coding: 0051915
VCID: 2F670D65BE066D1
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 252
Mileage: 142648 km
Time Indication: 0
Date: 2013.11.16
Time: 14:00:40
Address 46: Central Conv. Labels: 4L0-910-289.lbl
Part No SW: 4L0 910 289 F HW: 4L0 907 289 C
Component: Komfortgeraet H07 0050
Revision: 0050 --- Serial number: 01060591290000
Coding: 7632925
VCID: 336F0115522E491
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 43
Mileage: 142818 km
Time Indication: 0
Date: 2013.11.17
Time: 19:15:18
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000044510
Coding: 0000026
VCID: 2855E6799BE83A9
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 D
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000014523
Coding: 0012001
VCID: DEB900A1092C349
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0150
Revision: 00000000 Serial number: #g
Coding: 0051915
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000021
Part No: 7L6 941 329 A
Component: AFS-Modul links H06 0002
Component: AFS-Modul rechtsH06 0002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 388J 077651317
Coding: 0000002
Address 5C: Lane Maintain. Labels: None
Part No SW: 4E0 910 217 C HW: 4E0 907 217 C
Component: J759 LDW H06 0070
Revision: 00H06012 Serial number: 400207A1500094
Coding: 0000101
VCID: 2045FE59F3D8C29
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4L0 910 181 A HW: 4L0 915 181
Component: J0644 BEM H12 0690
Revision: -------- Serial number: 00000000031964
Shop #: WSC 07322 444 84037
VCID: 254BEF4DECFA271
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2710151156
Coding: 344630393135313035442056413032373130313531313536
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 9
Reset counter: 53
Mileage: 142818 km
Time Indication: 0
Date: 2013.11.18
Time: 01:54:19
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0150
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000600057218
Coding: 0062424
VCID: 2241F451FDD4D09
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000709030228
Shop #: WSC 12336 024 394758
VCID: 346D020957204E9
Address 69: Trailer
Cannot be reached
Address 6C: Back-up Cam.
Cannot be reached
Address 6D: Trunk Elect.
Cannot be reached
Address 6F: Centr. Conv. II
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 76: Park Assist
Cannot be reached
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
jsandlin491
Nov 24, 2013 10:56 PM
Rowdy_Audi
Jun 14, 2012 07:02 PM
ubdevoid
Mar 11, 2011 08:46 AM
meanse
Nov 13, 2007 03:04 AM
fenderstrat1184
Jun 18, 2007 03:30 PM
