VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VAGCOM tool
Old May 10, 2008 | 02:29 PM
ccomengee86's Avatar
Default VAGCOM tool
dasfdsfadf
Old May 12, 2008 | 11:00 PM
fischgrape's Avatar
Default RE: VAGCOM tool
ccomengee,
There are a few things that I would like to do with the VAG tool, and maybe some others could let us know if it's possible. They are:
a. change the key remote function to unlock all doorswith one button push, then open the windows and sunroof with a second.
2. enable daytime running lights
iii. keep foglights on when high-beams are engaged
D. lower the suspension a little bit
My guess is that a few Audi owners in one locale could chip in on one VAG thingee, and time-share it. Still, I don't want to mess too much with my CPO warranty.
Cheers,
john
Old May 12, 2008 | 11:34 PM
audiRSallroad's Avatar
fischgrape any method to your listing madness?
a. havent heard anyone doing this
2. and iii. after some research i found this, https://www.audiforums.com/archive/t...d-10695-1.html
its not vag but looks pretty simple if you really wanted the fogs as daytimes
and may not apply but if you were looking into hid fogs, http://www.sharphid.com/blog/index.p...t-hid-upgrade/
D. ive been looking into this myself and found the 402 mod, http://www.allroadfaq.com/downloads/mods/402_mod.pdf
hope thats some help
Old May 13, 2008 | 09:36 PM
ungawa's Avatar
I've bought the cheapo $10 vag com from Ebay. With it, you can use the outdated Vagcom software.. I forget which version. You are limited.
However I was able to change my lock settings to all unlock with one click.... hold again for all windows down. (no go on sunroof opening so far... however it does close when I hold the lock button) I also changed my locks so they auto-lock at 15mph or something... and they all unlock when I remove my key. Complete breakdown here... http://www.allroadfaq.com/content/conv_recode.shtml
I'm not positive, but I believe that those other mods are also possible with the basic vag-com cable. I now own 2 audis.. and plan on owning more audis once these are gone, so I'll probably drop the $$$ for the full Vagcom some day.
Edit: Memory serves something about 'daytime running lights' requiring some extra relays and wiring. I was thinking of a mod with the Vagcom that enables the fogs with high-beams. Haven't tried that one myself... but it's next.
Old May 13, 2008 | 11:46 PM
dsfadfsdfa
Old May 14, 2008 | 08:18 AM
ungawa's Avatar
ORIGINAL: ccomengee86
ORIGINAL: ungawa
What do you mean by opening/closing windows with a remote??
Can you open the windows before you actually getinto the car with a push of a button?? There are 4 buttons in a remote which includes Unlock, Lock, Trunk Release, and a Panic button.
Thanks in advance.
Shane.
Yes. Check out the link above. There are many choices and combinations of options. If I hit the unlock button on my remote once, all doors unlock. (instead of driver door... then other doors on second click) After that, if Ipress the unlock button a second time and hold itdown... all 4 windows open simultaneously until completely open or I release the button.
Say you walk away from your car and realize that one of your windows is open... or sunroof is open, no problem, just hold the lock button down and the windows will close.
bshusted
Jul 31, 2013 08:46 PM
desertsnake1991
Dec 11, 2012 07:00 PM
hxgaser
Apr 25, 2008 06:54 PM
dcllanos
Jun 28, 2007 12:21 AM
acowx
Apr 30, 2007 01:09 PM
