VAGCOM tool
ccomengee,
There are a few things that I would like to do with the VAG tool, and maybe some others could let us know if it's possible. They are:
a. change the key remote function to unlock all doorswith one button push, then open the windows and sunroof with a second.
2. enable daytime running lights
iii. keep foglights on when high-beams are engaged
D. lower the suspension a little bit
My guess is that a few Audi owners in one locale could chip in on one VAG thingee, and time-share it. Still, I don't want to mess too much with my CPO warranty.
Cheers,
john
Cheers,
john
fischgrape any method to your listing madness?
a. havent heard anyone doing this
2. and iii. after some research i found this, https://www.audiforums.com/archive/t...d-10695-1.html
its not vag but looks pretty simple if you really wanted the fogs as daytimes
and may not apply but if you were looking into hid fogs, http://www.sharphid.com/blog/index.p...t-hid-upgrade/
D. ive been looking into this myself and found the 402 mod, http://www.allroadfaq.com/downloads/mods/402_mod.pdf
hope thats some help
I've bought the cheapo $10 vag com from Ebay. With it, you can use the outdated Vagcom software.. I forget which version. You are limited.
However I was able to change my lock settings to all unlock with one click.... hold again for all windows down. (no go on sunroof opening so far... however it does close when I hold the lock button) I also changed my locks so they auto-lock at 15mph or something... and they all unlock when I remove my key. Complete breakdown here... http://www.allroadfaq.com/content/conv_recode.shtml
I'm not positive, but I believe that those other mods are also possible with the basic vag-com cable. I now own 2 audis.. and plan on owning more audis once these are gone, so I'll probably drop the $$$ for the full Vagcom some day.
Edit: Memory serves something about 'daytime running lights' requiring some extra relays and wiring. I was thinking of a mod with the Vagcom that enables the fogs with high-beams. Haven't tried that one myself... but it's next.
ORIGINAL: ccomengee86
What do you mean by opening/closing windows with a remote??
Can you open the windows before you actually getinto the car with a push of a button?? There are 4 buttons in a remote which includes Unlock, Lock, Trunk Release, and a Panic button.
Thanks in advance.
Shane.
ORIGINAL: ungawa
Thanks in advance.
Shane.
Say you walk away from your car and realize that one of your windows is open... or sunroof is open, no problem, just hold the lock button down and the windows will close.
desertsnake1991
Dec 11, 2012 07:00 PM
