Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Can I replace only two tires?
Old Nov 27, 2010 | 05:11 PM
gray113's Avatar
Default Can I replace only two tires?
So the other day i found an air bubble in the sidewall of one of the rear tires on my wifes 04 a4 quattro. Now I know I should probably replace all 4 tires since these ones have been on the car for a few years but we just got married a couple weeks ago so money is kinda tight right now. So my question is, will I damage anything by replacing only the fronts and having half worn tires on the rear?
Old Nov 27, 2010 | 06:39 PM
UberTeile's Avatar
Yes, preferably on the same axle. Unlike some other AWD systems out there, you won't risk damage to Audi's rock-solid Torsen diff by doing so.
UberTeile
Old Jan 12, 2011 | 11:29 AM
Miles@TireRack.com's Avatar
Right on UberTeile!
Audi recommends making sure that all of the tires are within 4/32'' of each other and with this in mind you can match on the same axle without detrimental results to the drivetrain.
If you have a few minutes, check out this article: http://www.tirerack.com/a.jsp?a=BY4&....jsp?techid=18
Old Feb 17, 2011 | 09:41 PM
beebe's Avatar
4/32, isn't that 1/8"?
Old Feb 17, 2011 | 10:11 PM
AWDaholic's Avatar
Senior Administrator
^^MATHaholic^^
Yep, but, 4/32 is 4x as precise!
To the OP:
Yes, you can replace only two, IF they're both front, or rear. But, It's generally not recommended, especially if, as you say, they tires have been on the car for a while. It's wifey's car and do you REALLY wanna play around with safety and potential mechanical problems on the wife's car like that? Take it from an old guy, don't risk anything you don't absolutely have to. If that tire fails at speed, nothing good could happen without divine intervention. If you replace only the front or rear pair, given the age of those tires, and it stresses the middle diff to the point of failure, again, at speed, it won't be pretty.
Do the right thing... Even if it hurts for the moment. Replace all 4 with something you can afford, and laugh about it, years and years from now, while you're sharing stories with your grand-kids.
Old Feb 18, 2011 | 12:42 PM
It's also 8/64! Even MORE precise
In the tire biz we refer to tread heights in 32's. It's just easier to pick one standard depth than to figure out different fractions all the time.
ttaylor
Sep 16, 2013 10:18 PM
audi_sf
Dec 20, 2008 08:27 PM
udo2000
Sep 25, 2008 08:20 PM
sollyd25
Nov 19, 2007 05:58 PM
thebbk
Sep 25, 2007 12:05 PM
