Airbag light
RE: Airbag light
Use a zip tie to physically hold the two halves of the connection together - to keep the two plugs from separating. It's a common problem on our cars. Mine is currently on also, because when detailing the car one day, I slid the seat all the way back. It must've put a little stress on the seat airbag connection, pulling it slightly apart and tripping the airbag light. By using a zip tie to hold the connection tight and solid, you can keep the fault from recurring. Zip tie it tightly, and then do as sean1.8t suggests (or turn it off with a VAGCOM if you have access to one), and you should be good to go.
RE: Airbag light
In case it's needed, would something like this do the job?:
http://www.diydiagnostics.com/advancedVW_specs.htm
RE: Airbag light
That code reader will turn off the light. Here is a list of code readers for VAG.
http://search.ebay.com/search/search...&category0=
HolyokeAudi
12-17-2014 09:13 AM
pologoped2
07-28-2013 05:47 PM
Niclipse
04-11-2011 05:29 AM
