Sponsored by:
Sponsored by:
Airbag light
Old 10-27-2007, 03:39 PM
SRG's Avatar
SRG
SRG is offline
Default Airbag light
Hello:
Does anyone know a quick fix for an airbag light? I have a 2001 A4 1.8T. The light came on a few months ago and has stayed on since. Thanks in advance for any advice/suggestions.
Old 10-27-2007, 08:14 PM
sean1.8t's Avatar
Default RE: Airbag light
there is a yello and purple conector underneath your driver's side seat. zip-tie it shut and wait for the code to go off by itself. or unhook the battery for about 30 minutes.. problem solved
Old 10-27-2007, 08:46 PM
SRG's Avatar
SRG
SRG is offline
thanks Sean, what specifically do you mean by zip-tying the connector? Just want to make sure I don't do something wrong.
Old 10-27-2007, 09:57 PM
ImTheDevil's Avatar
Use a zip tie to physically hold the two halves of the connection together - to keep the two plugs from separating. It's a common problem on our cars. Mine is currently on also, because when detailing the car one day, I slid the seat all the way back. It must've put a little stress on the seat airbag connection, pulling it slightly apart and tripping the airbag light. By using a zip tie to hold the connection tight and solid, you can keep the fault from recurring. Zip tie it tightly, and then do as sean1.8t suggests (or turn it off with a VAGCOM if you have access to one), and you should be good to go.
Old 10-27-2007, 09:58 PM
sean1.8t's Avatar
zip-tie it shut. bacically just what it sounds.. just make sure that the connectors are as tight together as possible and tie them together so they won't come apart
Old 10-27-2007, 10:06 PM
SRG's Avatar
SRG
SRG is offline
Should I disconnect the battery before messing with the connector? If this doesn't work, is there a relatively inexpensive reader I can buy to reset the fault code?
Old 10-28-2007, 01:23 AM
SRG's Avatar
SRG
SRG is offline
In case it's needed, would something like this do the job?:
http://www.diydiagnostics.com/advancedVW_specs.htm
Old 10-28-2007, 10:10 AM
CRAZYHAWK's Avatar
That code reader will turn off the light. Here is a list of code readers for VAG.
http://search.ebay.com/search/search...&category0=
Old 10-28-2007, 10:23 AM
BraMas's Avatar
Thans For the link I just bought this one
Universal CAN Pro-Series OBDII Trouble Code Reader
Old 10-28-2007, 10:54 AM
SRG's Avatar
SRG
SRG is offline
So if all you want to do it turn off a light, there shouldn't be any difference between a reader costing $50 and one costing $150.
HolyokeAudi
12-17-2014 09:13 AM
pologoped2
07-28-2013 05:47 PM
v8_ranch
08-27-2012 12:45 AM
geoff4
02-22-2006 04:01 PM
Quick Reply: Airbag light
