Sponsored by:
Sponsored by:
02 4.2 engine coolant temperature sensor replacement
Old 02-09-2008, 02:53 PM
gtzpower's Avatar
Default 02 4.2 engine coolant temperature sensor replacement
Ok, I have done this a number of times before on other cars, but I am thinking the audi's going to the dealer for a silly sensor replacement. Before it goes in the shop, I just wanted to make sure I am not missing something obvious here. All you have to do is pull the plastic retainer clip then pull the sensor out of the socket right? I pulled the clip (which broke cause 1 side was stuck in there), but the sensor wont budge a bit. I yanked and twisted and pulled, but no movement (the plastic above the clip rotates in the base, but the base held down by the clip doesn't move at all. I fear that I will snap it off if I keep trying at it! Am i missing something obvious here? I also cannot seem to figure out how to get the wiring connector off. Its just so frustrating sending it in for something so trivial. I mean for crikey's sake, even http://forums.audiworld.com/a4/msgs/2299786.phtml says its a 3 minute task to make the swap!
fergusjk
09-10-2012 08:35 AM
Pablo_Ottawa
10-05-2010 08:05 PM
Hunter007
08-09-2007 10:02 AM
ONIROI
03-05-2007 10:54 PM
A4NightRider
05-19-2005 12:25 AM
Quick Reply: 02 4.2 engine coolant temperature sensor replacement
