Sponsored by:
Sponsored by:
2000 2.7t wont start help please!!!!!
Old 01-12-2013, 01:16 AM
A6mark's Avatar
Default 2000 2.7t wont start help please!!!!!
i drove my 2000 2.7t today no problems, went out for a drink tonight when i came out the car wont start just keeps cranking? does anyone have an idea what it could be? it just keeps turning over and doesnt fire at all
Old 01-12-2013, 08:12 AM
02A6Beau's Avatar
could be just about anything. what kind of voltage are you getting from the battery? How much does it drop when the engine is trying to turn over? Could be something as simple as a corroded battery terminal, or it could be as complicated as everything else. start with the simple and work to the more complicated.
good luck
Old 01-12-2013, 08:29 AM
A6mark's Avatar
well it seems like the batt has pleanty of power its like there is no spark or it is out of gas i, really dont no what it could be
Old 01-12-2013, 08:36 AM
01 Avant's Avatar
pull a wire and crank to check for spark - if you got a spark then move onto the fuel system and also check fuses.
Old 01-12-2013, 02:51 PM
SilverSline's Avatar
Do you have Vag Com to check for any faults? Something like a bad Engine Speed Sensor usually will store a fault.
It is not too hard to remove the rear seat bench and the access panels to check the fuel pump. You should be able to hear the fuel pump run when your turn the key on. If not check for voltage at the fuel pump connector.
Hopefully its nothing too serious!
Old 01-12-2013, 09:51 PM
Jackmup's Avatar
crank it again. pull a spark plug out and see if it is wet.
check to make sure you have fuel in the tank
I would start with checking the fuel pump
you should hook a vag-com to it and pull the codes
the only way to check the spark is with "noids" look them up.
If i was to guess (and I am) I would start with the fuel pump as my first suspect.
you can test the fuel pressure at the fuel rail.
you can get a manual at bentleypublishers.com
Old 01-13-2013, 05:10 PM
A6mark's Avatar
Default update
well i went out the next morning and the car started right up? it did it again last night i put the key in and out of the ignition and it started, anybody have any thoughts on this?
Old 01-13-2013, 07:59 PM
nm3210's Avatar
Could be Coolant Temp Sensor? Has it only happened this once or does it sometimes crank longer during the cold?
Old 01-14-2013, 07:21 AM
A6mark's Avatar
it starts the same in the cold, it has happened twice now
Old 01-14-2013, 10:26 PM
Jackmup's Avatar
I've got 20 on the fuel pump.
when they are going out.
they work when they are cold and then seize when they get hot.
very rare they just quit on you.
CaptainPlanet
08-05-2014 12:00 AM
Dylan Cure
09-04-2012 04:21 AM
abookyent
08-20-2010 03:18 AM
millenia
03-31-2009 04:31 PM
Quick Reply: 2000 2.7t wont start help please!!!!!
