clutch, tranny, diffs or all of the above
Old Mar 10, 2008 | 08:16 PM
5speedaddict's Avatar
Default clutch, tranny, diffs or all of the above
Hello, I am new to the forum so hi there! I drive a 98 A4 Avant 5 speed 2.8L Quattro with 120K.
I recently purchased the car and have a few issues I am trying to figure out.
1. Every once in awhile I catch a burnt smell. After I stop the car I can't smell it outside, so I am nearly certain its not from the engine compartment. It seems to smell worse inside the cockpit. My feeling is that the clutch is going out, but I don't notice a slip. I usually smell it when I pull up to a light. (when I suspect the smell has a chance to float upwards)
2. There is noise when driving in 1st gear. It is a combination of a whining sound and a slight rattling. The rattling is almost like when your engine knocks when your trying to accelerate in too high a gear. The sound is completely gone once I shift into 2nd or higher. I have no problems shifting in or out of 1st gear, I just hear the sound.
3. I sometimes hear a faint humming/whining coming from the rear of the car. It sounds almost like a bearing in the rear end. I have never had a quattro before this, so am not sure if it is related to that. It is very faint, so much that accelerating drowns it out.
I couldn't find the search feature for this Forum, so my apologies if these are well discussed issues.
thanks
Old Mar 10, 2008 | 08:37 PM
1.8TK3MP's Avatar
Default RE: clutch, tranny, diffs or all of the above
answer to your questions as followed
1. maybe an oil leak onto your exhaust which makes funny smell, or if u have bypassed the carbon canistor from the intake system, its just a smell tht a car would make IF it was burning rich
2. water pump, steering rack/pump, some sort of exhaust mount rattling
3. muffler bearing
Old Mar 10, 2008 | 08:58 PM
thanks 1.8TK3MP
Not sure if those are it.
1. It doesn't really smell like burnt oil and if it was that, I might smell it after stopping the car. After I am stopped I usually walk around the card sniffing for it, but I never smell it or see any dripping. nothing is bypassed from what I can tell its all stock.
2. interesting, the water pump was recently replaced, it does sound like exhaust rattling, but it only happens in first. even if I start out in second gear I don't hear the noise. If it was some rattling of parts, wouldnt I hear it anytime the engine was under stress?
3. can you explain what a muffler bearing is and how it was cause the noise?
thanks for your help
Old Mar 10, 2008 | 09:11 PM
FASTER's Avatar
Tech Slut
my first gear sounded exactly like that for a very long time, like 45k miles... and after awhile the transmission blew. its very annoying when your in first gear and it sounds like ****. could be a chipped gear or bad synchro... ps. my transmission makes no noise now that i have the new one.
Old Mar 26, 2008 | 03:53 PM
Update on this. I took it to a shop and they told me the clutch was going out and the noise was a combination of shot bearings and a warped flywheel. Does this jive with the sound coming primarily in 1st gear?
jayson161
Jun 17, 2013 12:32 PM
skeezo3000
Apr 9, 2008 11:49 PM
skeezo3000
Dec 27, 2007 12:09 AM
dubblrest1985
Oct 17, 2007 01:37 AM
STD570
Jul 25, 2006 10:04 PM
