Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
aux cooling fan!!!!!!
Old Jul 25, 2009 | 08:53 AM
devolab's Avatar
Default aux cooling fan!!!!!!
My AR 2001 , aux cooling fan rum at high speed all the time , it sounds like a 747 lol..
Anybody ran into this before ??? It will stop as soon a press the eco button . and it will kick back when a turn the heat or ac no matter what temp, my control is at....
tahnks Paul
Old Aug 19, 2009 | 06:41 PM
copper07's Avatar
Sounds like the relay has gone bad.
Old Jan 4, 2010 | 12:57 PM
Taurean Bull's Avatar
Could you elaborate on the relay? Do you think blauparts would have a replacement? I have had the issue on my A6 for quite some time.
Like this?
http://cpwstore.carpartswholesale.co...3-1640908.html
Old Jan 22, 2010 | 05:40 PM
copper07's Avatar
I have not had to change the relay for my fan. The fuse on my fan blew, thus the fan never came on and the car overheated once in the summer. You are getting power to the fan, so the fuse should be good. You could always check and make sure the fuse is good.
Maybe someone could give more information.
Old Jan 24, 2010 | 09:57 AM
fjasper's Avatar
Default Check both electric fans
The fan controller is supposed to respond to a failed fan by running the other fan at higher speed, so you want to check and see if both fans (the one in front of the radiator and the one behind the radiator) are running. If one is not running, troubleshoot the fan. If both are running, it's probably the controller.
Old May 23, 2011 | 05:29 PM
lamonts's Avatar
Hi folks,
Did you get the aux fan running back as per normal operation? Was it the relay or the controller?
Thanks
JD_MILLS
May 16, 2012 06:29 PM
LKaler
Jul 26, 2010 11:38 AM
devolab
Aug 13, 2009 02:51 PM
ditallow
Mar 31, 2008 06:16 AM
jgm7507
Oct 31, 2007 07:33 PM
