Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
Odd question about Maintance I had done
Old May 5, 2015 | 09:50 PM
edwardgwright's Avatar
Default Odd question about Maintance I had done
I took my 2004 Audi Allroad in last week to have the timing belt and chains replaced as well as the water pump to a tune of 2000.00. I picked it up just right before the shop closed.
Well the engine used to be for the most part quite. Now I can here it a lot.
Also the car used to move like stink! Now not so much. Could this be the incorrect timing.
When I was coming home from the repair shop it almost tried to cut off 2 times.
Any comments or thoughts as to the problem? I will be taking it back to the shop tomorrow around 11 am est
Old May 6, 2015 | 08:13 PM
DOC ODDY's Avatar
If you have a way to read the codes, it might give you some clues.
Sorry, I can't begin to guess what might be the issue, but you may get to use that 2 year unlimited mileage warranty the repair shop gave you.
We have a 2001 2.7 twin turbo too, and no issues after a similar service, so please let us know what you find out about this.
Old May 6, 2015 | 10:30 PM
Ok so I went out this morning to start the car and what the noise! It was the inner cooler line on the drivers side was not hooked up at all. So I shut the car down! Took a few things apart and connected the hose. Not an easy task when your ring size is a 13. (So big hands don't really fit in tight places). So I then drove the car for a bit came home and opened the hood. All of a sudden I got a hiss sound and then smoke rolls up both side of the car. Then it stopped as quick as it started. Then their was a coolant hose on the overflow tank was leaking like no tomorrow! I got it all fixed then came home and installed LED tail lights and Slotted and drilled rotors with ceramic pads!
aeeroN
Nov 20, 2012 12:08 AM
savage1428
Jan 16, 2008 08:23 PM
02B6
Aug 29, 2007 06:06 PM
PandaXpress
Aug 3, 2007 10:12 AM
ATBOY
Mar 29, 2005 04:36 AM
