Audi A3 2006 Windscreen washer not working (tried every other tip)
Old Apr 7, 2018 | 06:20 PM
Paul18's Avatar
Question Audi A3 2006 Windscreen washer not working (tried every other tip)
Hi All
Hope you can help.
  1. I have a Dual Pump for the Front and Rear
  2. The washer on the rear works perfectly
  3. Always use screen wash (Ready Mixed)
  4. Sometimes, the front windscreen washer used to work, however, more frequently than not, 9/10 times it did not respond/work. Most recently, it does not work at all.
I have tried everything:
  1. Checked the water - fine
  2. Then checked the Fuse (tried 15A, 25A and 30A). Existing fuse is 15A - no change
  3. Removed nozzles, blew air into tubes - no change
  4. This suggested the pump may be the problem, so replaced the pump - no change
  5. Replaced stalk indicator - no change
  6. Checked the bonnet latch and made sure headlights are on - no change
Not really sure what else it could be.
Any suggestions?
Thank you
Paul
kacarlson65
Dec 16, 2012 06:19 PM
terrysummers
Jul 29, 2009 04:37 PM
Snapperanton
Jan 6, 2009 06:32 AM
gvm
Jul 25, 2006 02:51 PM
