Can't get my service indicator to reset
Old Mar 11, 2009 | 09:40 AM
ChaoticBliss's Avatar
Default Can't get my service indicator to reset
I must be missing something, I tried every possible thing I can think of to get my service indicator to reset but it is not working. I have an 09 A3 2.0. I pull out the right trip reset button, it says service overdue, I hold it, then it resets and says next service in xxx miles and then I let go. But the service due will still pop up after this. What am I missing?
Thanks
Old Mar 11, 2009 | 08:55 PM
ScottTBurg's Avatar
Default Service Reminder Reset
Go to forum tools and type in "service reminder." Doing so will take you to several threads that will tell you what to do. I had the same problem you described and someone helped me solve it before--it's posted in one of the threads.
Old Mar 12, 2009 | 03:39 PM
Ive read your post. It doesn't work for me. Pusing the RH stalk just resets my current trip and does not bring up the service indicator.
Old Mar 12, 2009 | 09:11 PM
ScottTBurg's Avatar
Default Reset Service interval
I did the following (from the owners manual) to mine this afternoon after a 35K oil/filter change yesterday. It worked and reset the service indicator for 10K miles.
"-Switch the ignition on.
- When the **** (right **** next to speedometer) is pulled, this message appeared "service"
-Pull the **** until SERVICE IN --- MI (KM)--DAYS appears in the display. If the reset button is not pushed within five seconds, the display reset mode changes."
Hope this works for you.
Old Mar 14, 2009 | 09:12 AM
Little confused as to what this part means "If the reset button is not pushed within five seconds, the display reset mode changes."
Does that mean I should push the reset button within 5 seconds? Pull the ****, wait till the next service indicator pops up, let go and press the reset button? Why are the instructions so vague?
And while we are on it, which one is the reset button?
Thanks
Old Mar 14, 2009 | 09:45 PM
ScottTBurg's Avatar
Unhappy Service Interval Reset
It is confusing. I was just quoting the manual. And, you're right it is vague.
The "reset" button is the one on the bottom of the right stalk off the steering column. To make my system reset, I pulled the **** (the right **** on the speedometer) out as per the instructions till the message appeared, then I pressed up on the reset button (on the right stalk). Doing so made the service interval reset for 10K miles.
Hope this works for you. As I said, it is confusing.
phillip.beattie
Oct 4, 2013 08:37 AM
jetmech09
B8 Models
Nov 27, 2011 02:10 AM
Jedward02
Feb 4, 2009 10:30 AM
converted
Oct 15, 2007 05:36 PM
roncpi
Mar 23, 2006 02:33 PM
