coolant level/temp warning light
Old Feb 2, 2016 | 09:56 PM
mattymo's Avatar
lynz-bee
1- I have a previous model year but I have had an engine coolant temp sensor issue for a long time. For my 06 version there are actually 2 engine coolant temp sensors that report to the ECU. The primary (rear of the engine block) reports to the ECU, the second unit (at the water pump/thermostat neck) appears to report primarily to the temp gauge in the dash. I have had intermittent engine temp gauge reporting in the dash for some time.
2- I would suggest a low cost (less than $50) OBDII code reader. Has been very helpful in troubleshooting my issues as well as family members with a nuisance "Check Engine Lamp" for very minor things.
3- Can't really say but if the wheel bearings need attention, that is a bit more than many home mechanics would be up to. Do make sure it's not just the tires first. You know, look at the tread, verify tire air pressures and lug nuts...
As far as the rear window, search for problems with the rear window regulator before assuming the motor is the issue.
shipo
Feb 8, 2015 04:52 PM
Mossyoakglock
Dec 22, 2010 03:25 PM
Ph3N0m
Oct 21, 2008 12:58 PM
ou2mame
Jan 22, 2007 10:49 PM
chriscollins
Jun 21, 2005 01:33 AM
