Inspection Light
Old Aug 10, 2013 | 06:31 PM
jozvaldo's Avatar
Default Inspection Light
I recently had a service by an independent guy on my 58 plate A3 but he was unable to turn the inspection indicator off (spanner light)
Can anybody help???
Do I need somebody with a diagnostics machine to switch it off?
I'm based in Beds if that helps..............
Thanks
Old Aug 11, 2013 | 09:54 PM
aspen79's Avatar
Not sure what a 58 plate A3 is but.........
If I remember correctly, start with the key OFF. Pull out and hold the right button in the cluster display, and while holding it out turn the key to POS 2 (ON). Release the button and within 5 seconds pull it out again. The service minder should go to all dashes. Release the button and turn the key to off. It should be reset then.
Old Aug 12, 2013 | 03:52 AM
jozvaldo's Avatar
Thanks for the reply but I have already done this and it only resets the oil check no that actual inspection???
Lefty
Apr 13, 2012 08:32 AM
eurotuner21
Dec 29, 2007 12:05 AM
wmdunk
Dec 18, 2007 11:01 PM
a6avant
May 4, 2007 08:45 PM
jammin414
Mar 14, 2005 08:51 PM
