**UPDATE**My BOV on B6 1.8T**Throwing codes like a mofo
Old Dec 22, 2007 | 06:24 PM
  #21
tdn's Avatar
tdn
Default RE: **UPDATE**My BOV on B6 1.8T**Throwing codes like a ****
ORIGINAL: Lazer Viking
i'll take that off your hands for $50 ?
A+ for effort.
Did you throw your stock dv out when you replaced it? I can't help you much, I'm just confused as to why you bought another stock dv.
Old Dec 22, 2007 | 06:34 PM
  #22
AUDI05's Avatar
ORIGINAL: chaos92287
yeah that hose should def. be plugged. large bolt and clamp would do it. dont give up on this yet. i can help you out when we get back to Tally, or i think khj677turbo is in Tampa
Ill pm khj677turbo. In the mean time I will plug the the hose to the res. If it continues to throw codes I will install the new stock dv, and we can tackle this in Tallahassee when we get back.
Original: tdn
A+ for effort.
My grandfather was watching me install the BOV, when I removed the stock dv I cut the vac line just abov the nipple b/c it was too hard to remove that small little clamp in that cramped space. Afterwards I handed it to him to look at. I turned my back and he had set to work trying to get that clamp off and broke the vac nipple off my old stock dv....Thats why I ordered a new one
Thank you all for your help so far, you've been awesome
Old Dec 22, 2007 | 06:46 PM
  #23
chaos92287's Avatar
yeah cause if air is rushing out of that hole, you would definitely be running rich and throwing a CEL. and if you need a stock dv, i could always mail you mine
Old Dec 22, 2007 | 07:55 PM
  #24
Karl's Avatar
Draw up a sketch of those hoses (using paint or someother basic program) so we can see what hose it is that has the whole.. there might be an easier alternative to plugging the whole
Old Dec 22, 2007 | 08:23 PM
  #25
AUDI05's Avatar
both ends of this house at the T are just sitting there open doing nothing.
Heres is a res that been pulled from a car, you can see a hole in the top... I don't know if mine has that hole and/or thats causing a problem too.
Old Dec 22, 2007 | 08:46 PM
  #26
Lazer Viking's Avatar
well, try plugging the bottom of the res t-fitting (the one by the bov in your digram, and connecting it at the top... , that way everything is either connected, or plugged off
pm returned btw
Old Dec 22, 2007 | 08:56 PM
  #27
AUDI05's Avatar
ORIGINAL: AUDI05
I could plug both ends of the "T" because both are open.
But What would I connect the top too?
Old Dec 22, 2007 | 09:47 PM
  #28
here's what im sayin
Old Dec 23, 2007 | 12:09 AM
  #29
cincyTT's Avatar
I'm make believe
Just now saw this thread.... THANK YOU for that pic above
Also, dont go blaming something until you know exactly what is the cause behind something. The air is probably leaking out of the res and throwing the code, the pic above should correct that since the res is still in place.
Old Dec 23, 2007 | 12:43 AM
  #30
AUDI05's Avatar
hmm, I wonder if that hose will reach.....
