1.8t sounds like a deisel
So i started to notice my 01 1.8t has developed this deisel like sound, so i went to replace the plugs and there was oil surrounding the plug and coil. i replaced the valve cover gasket and took care of the problem but i'm left with the sound still. it kind of sounds like the blow off valve (which is diverted back into the intake, please don't flame me) is fluttering all the time. any thoughts?
Someone stole your engine and gave you the first US A4 TDI!
Check to make sure you bov is running closed at idle, and that you don't have any vaccuum line leaks. My uncle had a similar problem on his Golf III and it was a vaccuum line fitting that had cracked.
well i have a code, but it's cause i have a test pipe and i haven't had a chance to check for any new codes. but the sound is noticable when i'm idle, or anytime i'm under 1 psi. like i said i'm getting a paint job right now so i can't pull up anycodes right now as much as i'd like too.
