1.8t sounds like a deisel
Old May 15, 2007 | 09:01 PM
ryansonfire's Avatar
Default 1.8t sounds like a deisel
So i started to notice my 01 1.8t has developed this deisel like sound, so i went to replace the plugs and there was oil surrounding the plug and coil. i replaced the valve cover gasket and took care of the problem but i'm left with the sound still. it kind of sounds like the blow off valve (which is diverted back into the intake, please don't flame me) is fluttering all the time. any thoughts?
Old May 15, 2007 | 09:05 PM
CLX's Avatar
CLX
Zombie Defense Force
Default RE: 1.8t sounds like a deisel
Someone stole your engine and gave you the first US A4 TDI!
Check to make sure you bov is running closed at idle, and that you don't have any vaccuum line leaks. My uncle had a similar problem on his Golf III and it was a vaccuum line fitting that had cracked.
Old May 15, 2007 | 11:09 PM
Lazer Viking's Avatar
missfire ?
Old May 15, 2007 | 11:21 PM
i was thinking about that but the cel should be flashing if it misfires, i had to get some body work done so i can't pull any codes from it until later next week.
Old May 16, 2007 | 12:12 AM
BaconBait's Avatar
When does it do it? Is it only on start up or is all the time?
Just because the CEL isn't on doesn't mean you don't have any codes.
Old May 16, 2007 | 12:45 AM
well i have a code, but it's cause i have a test pipe and i haven't had a chance to check for any new codes. but the sound is noticable when i'm idle, or anytime i'm under 1 psi. like i said i'm getting a paint job right now so i can't pull up anycodes right now as much as i'd like too.
Old May 16, 2007 | 08:13 AM
ironman's Avatar
My car sounds like diesel at startup then quiets down after 2 secs, i think its when ive built back pressure. Anyway well wait till you get codes
02A4kid
Apr 10, 2014 04:49 AM
lalanthak
Jun 20, 2012 12:08 PM
sheepcan
Feb 20, 2007 06:44 PM
