10 Engine Fault Codes
Old Jun 26, 2006 | 04:53 AM
BaconBait's Avatar
Default RE: 10 Engine Fault Codes
I'll give it a shot. Any recommended spark plugs. Currently they're Bosch +4.
Old Jun 26, 2006 | 05:57 AM
mrhurst88's Avatar
man, no joke when i checked mine a while back i had 10 too....mine were all vacume related tho, and o2.
Old Jun 26, 2006 | 08:43 AM
toyolla86's Avatar
yea i would bet that your getting all those codes caused from one problem. like fuel too lean.
that could cause each cylinder to indiviually misfire and many other false indications.
of course check whats cheapest first ie vacuum leaks. but if all that fails go with fuel problem.
Old Jun 26, 2006 | 01:40 PM
onepoint8tee's Avatar
ORIGINAL: BaconBait
NGK BKR7E for BT.
NGK BKR6E for K04 or just chip.
OEM's for stock.
Old Jun 30, 2006 | 10:19 AM
BaconBait's Avatar
NGK BKR7E's are in. It's running much better. Thanks.
Old Jun 30, 2006 | 01:45 PM
CRAZYHAWK's Avatar
The 7's are slightly cooler than 6's. If they carbon foul switch to 6's.
Old Jun 30, 2006 | 01:54 PM
dafrazi's Avatar
I got a set of the Bosch F7LTCR plugs and a set of the each of NGK BKR7E and NGK BKR6E plugs. Just let me know if you any of them and I'll pass them onto you the next we see each other.
vassar007
May 26, 2010 05:25 PM
chapdiggy
Sep 18, 2008 08:01 PM
chapdiggy
B7 Models
Sep 7, 2008 07:52 PM
marko_tomas13
Aug 9, 2008 01:49 PM
michaelh305
Jul 29, 2008 06:20 PM
