2.8 metal oil pan gasket???
Old Aug 27, 2007 | 05:42 PM
LowA4's Avatar
Default 2.8 metal oil pan gasket???
I have a slow leak that I'm fixing and I tracked it down to the lower pan gasket. Anyhow, I pulled the pan and there is a super thin metal gasket. Is that normal on Audi's? I know the previous owner replaced a cracked pan and am not sure which gasket he put on. I was just going to lay a thick silicone bead around the pan, would that work ok?
Old Aug 30, 2007 | 01:20 PM
dombombBMX's Avatar
Default RE: 2.8 metal oil pan gasket???
i had the same problem and sich.. i got the metal oil pan gasket - from the deal it seems 2 be working good
Old Aug 30, 2007 | 02:09 PM
auditech79's Avatar
The dealer uses a special sealant around the oil pan, don't use just any silicone as that may end up leaking.
The steel gasket will work just not as long.
Old Aug 30, 2007 | 02:17 PM
LowA4's Avatar
Yea, I used rtv blue and it's seeping through a little. I have to change the oil again so I will just redo the sealant too. Is it a sealant I can get at an auto parts store or just the dealer?
Old Aug 30, 2007 | 02:20 PM
techbod's Avatar
if you go to the place that fits windshield and buy the black rubber glue they use its the best stuff you can get and not expensive
Old Aug 30, 2007 | 02:25 PM
LowA4's Avatar
Sweet, thanks.
Old Aug 30, 2007 | 09:33 PM
LowA4's Avatar
How shold I put the sealant on that I got from the glass shop? I'm not sure if I should let it sit for any amount of time before reinstalling the pan. It's a good thing that I pulled the pan to reseal it because some of the rtv sucked up into the pump screen and was about 75% covered, dodged a bullet there.
Old Aug 30, 2007 | 11:56 PM
auditech79's Avatar
Yeah thats why you have to be careful of how much silicone you put on there when installing the pan, this is what the bead should look like. Don't wait longer than 5 minutes after laying down the bead to install it back onto the car.
Old Aug 31, 2007 | 12:52 AM
LowA4's Avatar
Yep, that's how I put the bead. Thanks.
Andronikus
Aug 20, 2015 08:40 PM
LindaLu
Jan 4, 2015 09:14 PM
Keith Kessler
Feb 19, 2012 08:50 AM
whitey
Apr 15, 2009 03:03 PM
robert.jones
Dec 10, 2008 07:56 AM
