2002 1.8 T washer pump
Old Feb 6, 2006 | 01:57 PM
Audi42005's Avatar
Member
Default 2002 1.8 T washer pump
does anyone know how to get to the bottom of the windshield washer resivior where the pump is located? i think my pump went out but i am unable to figure out why the headlight sprayers still don't work and i can't get to where the pump is located....the only way i know how to is take off the driver side fender...????
Old Feb 6, 2006 | 02:58 PM
02tq's Avatar
Default RE: 2002 1.8 T washer pump
I have a 2002 1.8t as well. I thought my pump was broke turned out it was just a fuse, check the fuse before you start anything.
Old Feb 6, 2006 | 08:45 PM
AudiTech04's Avatar
There is a tech bulliten on this issue and it says to replace the pump and insert a 30 amp fuse
You also need to put a little splash shield on the pump to pevent water from destroying it again
You can access the pump from under the car
When you get the new pump there will be a different male connector on it just take it to the grinding wheel
Jeffla
Nov 25, 2010 10:09 AM
Trey25
Mar 22, 2008 11:06 PM
tealetm
Jan 14, 2008 03:01 PM
a3square
Feb 21, 2007 08:17 AM
Willfulone
Jan 26, 2005 01:58 PM
