98 b5 18t 5spd quattro check engine and some knocking noise
Old Jul 24, 2007 | 10:27 PM
dmakarov's Avatar
Default 98 b5 18t 5spd quattro check engine and some knocking noise
HELP A NEW AUDI OWNER
Bought an audi a4 18t 1998 5spd quattro
and having some problems with it
check engine light (cel) came up
when the outside temp was like 100C
then within a week the cel still there and i had about 4 times where you the car failed to start only after 10-15 mins of trying
Problem #1
VAG-COM Version: Release 409.1-US
Control Module Part Number: 8LO 862 257 B
Component and/or Version: CV-Pump, Alarm, RC D03
Software Coding: 16140
Work Shop Code: WSC 06335
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 558 M
Component: 1.8L R4/5VT MOTR HS D01
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
Readiness: 0000 0000
Address 01: Engine
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
Readiness: 0000 0100
Problem #2
has some kind of noise from pass side front suspension area
i checked the axle the boots are nearly new
sound gets louder when at higher speeds past 20mph and gets even louder when u turn right at high speeds
Problem #3
at about 5-10mph when pressing brake something clicks where front suspension is at
even if you go reverse and you press brake
clicks once every time you try to stop
Problem #4
The shifter jerks a little sometimes
but thats not from down shifting u could be taking it at low rpms and just kind of let go of the pedal and press it back slowly
the shifter jerks back and forth not the whole car
Problem #5 where is the alarm hood triger located and how is it mounted any one have a picture
ANy help would be apriciated
Old Jul 24, 2007 | 11:40 PM
01A4T's Avatar
Default RE: 98 b5 18t 5spd quattro check engine and some knocking noise
Im a little rusty at my conversion rates, but I believe 100*C would be about 200-215*F. I think at that point your skin would be melting off and you would not have to worry about your car anymore
Old Jul 25, 2007 | 01:58 PM
dmakarov's Avatar
sorry it was 100F
Old Jul 25, 2007 | 02:51 PM
acetrebo's Avatar
Problem 1 - probably the coolant temp sensor replace it, clear all codes, see if any come back
Problem 2 - probably a bad cv joint
problem 3 - check the clip that hold the brake pads in place, maybe its come loose. Sounds like the pads are moving around a bit.
problem 4 - not sure, doesnt sound like an issue
problem 5 - Ill see if I can find this and post later if no one else has.
Old Jul 25, 2007 | 03:03 PM
techbod's Avatar
ORIGINAL: dmakarov
Problem #1
2 Faults Found:
35-00 - -
35-00 - -
Address 01: Engine
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
P1136 - 35-00 - -
Address 01: Engine
Coding: 06201
Shop #: WSC 06335
1 Fault Found:
Problem #2
Problem #3
Problem #4
nothing of the bold corresponds with the last bit so whats the actual problem??
Old Jul 25, 2007 | 04:36 PM
CRAZYHAWK's Avatar
https://www.audiforums.com/m_361655/tm.htm
Old Jul 25, 2007 | 05:47 PM
acetrebo's Avatar
I think this part says it all for his first problem (then within a week the cel still there and i had about 4 times where you the car failed to start only after 10-15 mins of trying)
Old Jul 29, 2007 | 12:22 PM
dmakarov's Avatar
ok the replacing coolant temp sensor solved the starting problem
code is gone for it and it starts every time
now i think i have a very bad gas cap and i will be replacing the first thing tomorrow because
when the car is idling in neutral for couple minutes you can actually hear the gas cap sucking the air in
Alpinistshan
Mar 23, 2013 09:55 PM
ca12bon
Jan 13, 2013 09:12 AM
whtturboa4
Aug 17, 2010 02:10 PM
laosvegas
Sep 30, 2008 10:21 AM
diehlryan
Jul 9, 2007 02:03 PM
