99' a4 no cruise control, vaccume leak??
Old Dec 26, 2006 | 04:09 PM
ruby's Avatar
Default 99' a4 no cruise control, vaccume leak??
My cruise control has been funny since I have bought my car around 3 years ago. If i turn it on, it will go on for around 20 minutes through maybe an hour, then kick off... It won't turn back on until the unit has 'cooled' down, or something. I have seen some posts that there is a faulty switch in there, but before I go taking apart my steering wheel to get at that circuit board, does my problem sound like a vaccume leak or strictly electrical?
Thanks for any input you guys provide
Old Dec 26, 2006 | 04:14 PM
techbod's Avatar
Default RE: 99' a4 no cruise control, vaccume leak??
not sure on this one ( does it have a sleep timer ) I don't like the cruise my self it takes the sting of driving although my JAG has it
Old Dec 26, 2006 | 07:30 PM
ruby's Avatar
It's not the sleep timer, because it wont go back on for around 1 hour after it dies... hehe I drive alot of highway and it makes things alot easier.
Old Dec 26, 2006 | 09:34 PM
tractioncontrol's Avatar
No you don't have any vaccume line problems causing the issue. If it has all of the sudden stopped working all of the time check your brake lights (the cuise control on alot of cars is shut off by the brake lights and a bad bulb disables the cruise control).
Old Dec 27, 2006 | 12:05 AM
karageorge2's Avatar
I've had the same type of problem and haven't been able to fix it yet-A4 99.5.
Basically your cruise control consists of according to Haynes:
-the servo motor
-cruise control module (inside the dash-behind top part of dash) guy on e-bay checks and fixes these (wasn't my problem)
-vacuum pump
-brake & clutch vent valves located on pedals (rarely the problem) don't waste ur $.
-vacuum signal amplifier (haven't explored this one yet)
The brake lights either not functioning or wrong bulbs can cause cruise control probs. Best place to start looking.
Also a long rod connects to the throttle body make sure that the rod is connected (clipped in) to the rubbervacuum thingy under the throttle body.
gluck
ninjatturtle
Nov 16, 2008 05:18 PM
pa4ul
Feb 4, 2008 09:23 PM
rpavkov
May 4, 2007 01:59 PM
kstrike155
Sep 19, 2006 02:43 AM
A4 the Quattro
Mar 16, 2006 07:07 PM
