a4 2.6 v6 1996 starter motor
Old May 15, 2007 | 02:41 PM
rich1949's Avatar
Default a4 2.6 v6 1996 starter motor
My starter motor needs replacing so I have unbolted itbut I cannot manouver it out of the engine bay. Does anyone have any suggestions? Also does anyone know where I can get a workshop manual?
Old May 15, 2007 | 02:57 PM
techbod's Avatar
Default RE: a4 2.6 v6 1996 starter motor
you have to drop the exhaust on that side and they dont do a workshop manual for it
Old May 15, 2007 | 03:01 PM
techbod's Avatar
this link has all you need to know about your car ( remember the 2.8 is the same )
http://www.12v.org/
Old May 23, 2007 | 08:09 AM
rich1949's Avatar
Default RE: a4 2.6 v6 1996 ignition switch
HI, THANKS FOR THE INFO ON THE STARTER MOTOR,BUT HAVE JUST FOUND OUT THE PROBLEM IS THE INGITION SWITCH .I NEED TO REMOVE IT ,I HAVE REMOVED THE TOP COVER ON THE STEERING COLUMN BUT THE BOTTOM COVER WILL NOT COME OFF.I WAS GOING TO REMOVE THE STEERING WHEEL BUT DO NOT KNOW HOW TO & AM A BIT APPREHENSIVE ABOUT THE AIR BAG,CAN YOU HELP?. REGARDS RICH.
Old May 23, 2007 | 09:38 AM
Redrum1's Avatar
There was a factory recall for ignition switches in those years. Why don't you check with your dealer first?
I just got a card on mine but haven't got to a dealer yet.
Old May 24, 2007 | 10:41 AM
rich1949's Avatar
I WILL GET TO A DEALER AS SOON AS I CAN,IN THE MEANTIME I WOULD STILL LIKE TO KNOW HOW TO REMOVE THE STEERING WHEEL. REGARDS RICH.
Old May 24, 2007 | 10:52 AM
techbod's Avatar
Repairing driver's airbag[/align]Removing and installing steering wheel[/align]
â—†Removing
‒Remove airbag unit
‒Centre the steering wheel (wheels in straight-ahead position).
‒Unscrew bolt -8[size=-1]9-.
‒Detach connectors -12[size=-1]13 and 14[size=-1]15-. [/ul]
â—†Installing
‒Attach steering wheel in centre position (wheels straight ahead).
‒Ensure that the connectors and the airbag engage fully (i.e. audibly).
‒Replace bolt -24[size=-1]25- and tighten to 60 Nm.
‒Install airbag unit[/ul][/ul]
[IMG]local://upfiles/12092/BE518885006D4702B3D533A3B0EA5CAA.jpg[/IMG]
Old May 24, 2007 | 11:22 AM
CRAZYHAWK's Avatar
rich1949, turn off the caps.
Old May 30, 2007 | 08:30 AM
rich1949's Avatar
I HAVE REPLACED THE IGNITION SWITCH (THE OLD ONE WAS CRACKED & RETURN SPRING DISPLACED) BUT ENGINE STILL WONT START. THE STARTER MOTOR SPINS WHEN I JUMP THE TWO MAIN TERMINALS ON IT. I HAVE BEEN TOLD IT COULD BE THE RELAY,BUT CANNOT LOCATE IT.
Old May 30, 2007 | 03:54 PM
rich1949's Avatar
Hi,thanks for your help,I have replaced the starter motor & Ignition switch(which was cracked & return spring displaced)But engine still refuses to start.The starter motor spins when i jump the two main terminals on it, I have been told that it could be the starter relay, but cannot locate it.
rustybolt
Sep 28, 2014 11:04 AM
SavgeA4
Sep 26, 2012 12:08 PM
Dan_89
Jan 3, 2012 05:31 PM
Sakasama8
Mar 28, 2009 01:45 AM
MeanAudiA6
Jan 3, 2007 01:13 AM
