A4 Radio
Old Nov 30, 2004 | 04:44 PM
roger's Avatar
Default A4 Radio
hi, has anyone put an Audi radio in there A4 ? looking at the back of either the chorus, concert of gamma there are only 4 connections for the speakers which means only the rear or front set of speakers work, but i have 8 speaker wires !!!!!!
Audi cant help niether can the auto electricians i've been too!!!!!!
HELP...
Old Nov 30, 2004 | 04:46 PM
shon's Avatar
Default RE: A4 Radio
there is no reason the have 8 on the radio since you can only fade front to back...
one goes to the front one goes to the back...
Old Dec 2, 2004 | 03:14 PM
roger's Avatar
so can anyone help with my radio situation ? i've been told i dint need 8 wires.....but 8 wires is what i have ! so how do i proceed as i'm not an auto electrician ? and east london audi dealers offer no solutions.....
Old Dec 2, 2004 | 04:46 PM
Daytona A4QV6's Avatar
depending on the ohm ratings of the speakers.... you may be able to run them in series. It all depends on how car stereos are setup. I have alot of experience setting up PA systems, but not much w/ cars.... Example... an 8 ohm speaker run in series will drop it down to 4 w/ an added speaker on each channel, and so on. The speakers just need to be designed to handle the ohms.
http://www.rexc.com/services/ohms.htm ..........this may help you understand
Old Dec 2, 2004 | 05:30 PM
Jestnomen's Avatar
6th Gear
Ok here's why...
On the back of the radio there are 4 connections for speakers. These connections are used for non-bose audi's.
speaker line, right-front (+)
speaker line, right-front (-)
speaker line, left-front (+)
speaker line, left-front (-)
A low level (RCA) line runs to the rear speakers to the built in amp on the left speaker.
On bose equiped Audi's none of the speaker lines are used. The low level line goes to the rear amplifier on the rack behind the seat.
The low level lines consist of:
Line out, left-rear
Line out, right-rear
and a common low frequency ground.
Delta System Non-Bose
Old Dec 2, 2004 | 09:21 PM
dudley doright's Avatar
Default How would I know if I have a Bose?
Jestnomen,
How can I tell if my car has the Bose system?
Old Dec 2, 2004 | 09:30 PM
Jestnomen's Avatar
6th Gear
Default RE: How would I know if I have a Bose?
Stick your head in the trunk. If it is Bose, there should be a black amplifier bolted to the side wall of the drivers side.
Marine702
Jan 27, 2013 07:10 PM
Starvagabond
Sep 6, 2012 07:14 PM
akobeszko
Mar 13, 2012 03:02 AM
BOBB98.5A4QT
Jun 1, 2008 02:10 PM
