A4 will not start
I need some help, I had to clean the IP cluster gauges because some dirt got behind the plastic from the previous owner. I disconnected the gauge cluster, cleaned it but the immobilizer is keeping me from starting the car. Is there a way to reset the system? In some cars you disconnect the battery, someone eles told me to turn on the ignition for 2 minutes, off 2 minutes and that should reset it.
vagcom reset - hook up a computer to your car - use ross-tech software to reset everything
lookie what I found
http://www.ross-tech.com/vag-com/car...-swapping.html
lookie what I found
Vict0ar
Apr 3, 2014 08:38 PM
kinnes042
S4
Apr 10, 2013 06:29 PM
brit.mike13
Oct 17, 2010 08:26 PM
