A4 will not start
Old Apr 15, 2007 | 08:01 PM
rbr5000's Avatar
Default A4 will not start
I need some help, I had to clean the IP cluster gauges because some dirt got behind the plastic from the previous owner. I disconnected the gauge cluster, cleaned it but the immobilizer is keeping me from starting the car. Is there a way to reset the system? In some cars you disconnect the battery, someone eles told me to turn on the ignition for 2 minutes, off 2 minutes and that should reset it.
Old Apr 15, 2007 | 08:06 PM
Flip's Avatar
Default RE: A4 will not start
Try disconnecting the battery, I'm not sure if it works for these cars but it is worth a try.
Old Apr 15, 2007 | 08:25 PM
rbr5000's Avatar
I did for about 10 minutes, now I can't lock or unlock the car with the key. I will try for longer and see if I can get it reset. But it seems to geting worse.
Old Apr 15, 2007 | 10:32 PM
david9999's Avatar
DId you reconnect every connection? If so, you may need a vagcom to reset.
Old Apr 15, 2007 | 10:46 PM
rbr5000's Avatar
Ok you got me, david9999 what is a "Vagcom Reset"?
CRAZYHAWK's Avatar
What year is your car?
Old Apr 15, 2007 | 10:59 PM
rbr5000's Avatar
2004 A4 3.0 6spd
Old Apr 15, 2007 | 11:04 PM
akielb's Avatar
vagcom reset - hook up a computer to your car - use ross-tech software to reset everything
lookie what I found
http://www.ross-tech.com/vag-com/car...-swapping.html
Old Apr 17, 2007 | 01:29 PM
rbr5000's Avatar
The dealer has my car, he says its the IP gauge cluster has a short in it and needs replacing, good thing it's all under warranty!
Chito
Jun 28, 2010 08:48 PM
mark944turbo
Oct 10, 2005 05:51 PM
