abs repair advise/help
Old May 18, 2007 | 12:13 PM
ddd's Avatar
ddd
Default abs repair advise/help
has anyone tried to have there abs module replaced by buying a new module from ecstuning here?
http://www.ecstuning.com./stage/edpd...mp;engine=1.8T
they have these part numbers 8EO 614 111E or 8EO 614 111A, # is 8EO 614 111F,
# is 8EO 614 111G,
# is 8EO 614 111P or 8EO 614 111Q,, # is 8EO 614 111R or 8EO 614 111S,
# is 8EO 614 111AH or 8EO 614 111AJ.
but I my part number is
8EO 614 111AB. I emailed them and they seem not to know either.
My car is a 2000 model 1.8t with VIN # WAUZZZ8DZYA149296 and engine # APU 058543.
help.......
Old May 18, 2007 | 12:18 PM
auditech79's Avatar
Default RE: abs repair advise/help
Give your part number to the audi parts department, the part number may have been changed to an updated version.
Old May 18, 2007 | 12:23 PM
techbod's Avatar
whats the problem first?
Old May 19, 2007 | 06:04 AM
ddd's Avatar
ddd
the dealer told me that the abs module is shot. to fix it it would cost the equivalent of $ 2,200 cause they said they can only replace the whole assembly and not just the module.
So I was thinking of buying a new module from ecs since i will be going to the US next month. Thats why its very important for me to buy the right one cause its gonna be tough to send it back all the way to the US if its not the right part. thanks
Old May 21, 2007 | 11:19 AM
ddd's Avatar
ddd
bump, anyone......
Old May 21, 2007 | 11:34 AM
headshok2002's Avatar
There are guys on eBay that offer rebuilds on them... it's a few hundred bucks I think.
Do you have a flashing ABS light?
Right now, my ABS kicks in every single stop I make... but it's not my ABS module that's shot. I've got a cracked ABS relucter ring in my CV joint.
EDIT: here's a link. There are cheaper ones on eBay, though... but these guys seem decent. http://cgi.ebay.com/ebaymotors/VW-Pa...31088354QQrdZ1
Old May 21, 2007 | 11:44 AM
whitejeepXJ's Avatar
ORIGINAL: headshok2002
Sorry to jack your thread but I had the exact same symptom, ABS comes on at almost every single stop even if I was going 2mph... I thought I had a sensor that was gone but the shop told me that when they plugged it in and drove around the abs would come on and then off (the system)... so they say i need a whole new module... I didnt have an ABS light on though thats what i find weird.. I now unplugged the system and run without it...
Do you think it could have just been a cracked ABS relucter ring also?
Old May 21, 2007 | 11:55 AM
Yes, I think it sounds like my problem for sure. As far as I knew, a bad ABS module would result in a light on the dash.
With my problem, my ABS module is working exactly as it should be... it's just being tricked into thinking one wheel is spinning at a different speed than the others because the relucter ring is cracked.
You have any work done to the car prior to this problem? For me, it was a wheel bearing job... the ring got cracked (or was cracked, but actually became a problem) after that job.
Old May 22, 2007 | 11:20 AM
ddd's Avatar
ddd
ORIGINAL: auditech79
thanks, i will try that....
scootera
Aug 12, 2012 05:36 PM
redhammer
Jan 2, 2009 07:08 PM
vegastt
Jun 9, 2008 08:30 PM
Victo_Peru
Sep 23, 2006 01:18 PM
hypnotiks
Mar 26, 2005 12:00 AM
