Accessing sunroof track....Headliner removal?
Old Oct 6, 2005 | 03:41 PM
gregp1962's Avatar
Default Accessing sunroof track....Headliner removal?
I mentioned in my other post that the sunroof cover has slid way back and is stuck and has the sunrof stuck open. I'm going to have to get access to my sunroof track. I'm thinking that I have to remove at least part of the headliner.
Is removing part of the headliner, in fact, the way to access the sunroof track and be able to get to the back portion to pull the stuck sunroof cover forward?
Old Jun 19, 2007 | 11:20 AM
Dungar46's Avatar
Member
Default RE: Accessing sunroof track....Headliner removal?
Having the exact same problem. I have most of the headliner pulled. But can't for the life of me find the screws on the tabs that the visors clip to.
Old Jun 21, 2007 | 05:20 PM
D4ves's Avatar
You have to pop the whole plastic cover off the visor tabs and the screw is underneath. Best way is to insert a flat screwdriver in front of the spring plate thingy in the centre and pop the cover of from inside the front face (facing you) rather than from the screen side behind!?
I started off being kind and gentle, but sometimes you've gotta be firm with it!
I'm trying to figure out what's holding the lining around the sunroof opening itself as everything else supporting it is off!! (can't seem to get a reply/response to thatpost tho').
Old Jun 21, 2007 | 06:13 PM
D4ves's Avatar
Also....found this
https://www.audiforums.com/m_90742/tm.htm
Bookmark it...I have!
psonoda
Jul 29, 2018 04:53 PM
etzbseder
Mar 6, 2012 01:29 PM
MidnightB5
Jan 11, 2011 09:46 PM
bluesnapper
Nov 10, 2006 03:49 PM
mapin
Oct 19, 2006 01:03 AM
