Airbag Light
grounding problem, remove the ground wire from the battery then clean all ground wire connections, possibly a battery to engine chassis or engine ground problem grease or copper slip connections, the temp should not have any effect on the airbag system this could be a recall issue
ORIGINAL: swift_A4
i have a weird problem where when it is below freezing (in the 20's) when i start my car the airbag light is on, after a minute or so it spurraticly flashes, then goes away, really weird.
Plugged in my VAGCOM and there were no error codes stored.
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
Niclipse
Apr 11, 2011 05:29 AM
