Airbag Light
Old Nov 30, 2006 | 05:11 PM
Dunzie182's Avatar
Default Airbag Light
My airbag light came on the other day and won't go away. Does anyone know how to fix this? Is it just a sensor or could it be the whole airbag?
Old Nov 30, 2006 | 05:13 PM
JohnnyBravoA4's Avatar
Default RE: Airbag Light
if you dont have a vag-com then you have to go to the dealer to get it reset, it may or may not come back on.
Old Nov 30, 2006 | 05:41 PM
Ford2Audi6's Avatar
I did mine twice already, you can scan it with an obd II and get the code. clear the code and the start the car and see if it comes back.
Old Nov 30, 2006 | 06:53 PM
swift_A4's Avatar
i have a weird problem where when it is below freezing (in the 20's) when i start my car the airbag light is on, after a minute or so it spurraticly flashes, then goes away, really weird.
Old Nov 30, 2006 | 07:00 PM
techbod's Avatar
grounding problem, remove the ground wire from the battery then clean all ground wire connections, possibly a battery to engine chassis or engine ground problem grease or copper slip connections, the temp should not have any effect on the airbag system this could be a recall issue
Old Nov 30, 2006 | 07:06 PM
MC Hammered's Avatar
ORIGINAL: swift_A4
I just this happen to me a couple of days ago as well.
Plugged in my VAGCOM and there were no error codes stored.
Old Nov 30, 2006 | 07:10 PM
techbod's Avatar
+ or minus centigrade metal shrinks and expands on sever temps you know
HolyokeAudi
Dec 17, 2014 09:13 AM
pologoped2
Jul 28, 2013 05:47 PM
v8_ranch
Aug 27, 2012 12:45 AM
Niclipse
Apr 11, 2011 05:29 AM
geoff4
Feb 22, 2006 04:01 PM
