any thoughts on this code...?
Old Mar 3, 2006 | 10:38 AM
jja2.8's Avatar
Default any thoughts on this code...?
P1392 Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
Old Mar 3, 2006 | 10:55 AM
Jestnomen's Avatar
6th Gear
Default RE: any thoughts on this code...?
Yikes get your car looked at. I would not drive it again. Could be a bad camshaft sensor or timing belt slipped a tooth. Is the car running fine?
Old Mar 3, 2006 | 11:03 AM
prodrive's Avatar
looks like a bad sensor or harness.
Old Mar 3, 2006 | 11:07 AM
jja2.8's Avatar
i have not driven it since the CEL came on a few days ago. last night i ran vag-com, got that code and cleared it. this morning i started it up for the first time since the CEL came on, and it ran rough for a few seconds then i shut it off. CEL was still on.
Old Mar 3, 2006 | 11:25 AM
Jestnomen's Avatar
6th Gear
Are you able to do your own maintenance? Replacing the camshaft position sensor is pretty easy.
Old Mar 3, 2006 | 11:45 AM
jja2.8's Avatar
yeah sounds like something i can handle. hopefully i can find one locally so i can install it this weekend.
thanks for the info
Old Mar 3, 2006 | 10:48 PM
jja2.8's Avatar
just replaced sensor, no change still trips code and CEL is back.
timing belt is only 3k miles old, think it could slip a tooth?
any other thoughts?
Old Mar 4, 2006 | 02:16 AM
TroyS's Avatar
If that code is accurate, I would imagine that that wire goes straight to the ECU, might do a "quick" continuity check from the cam sensor to the ECU. You'd have to get some extra wire to extend the range of your multimeter (assuming ya got one).
Jeff M
Jul 18, 2011 06:46 PM
vtecgreen
May 22, 2008 11:32 PM
mr.cAp
Jan 3, 2008 11:17 PM
Siggy
May 28, 2007 12:57 AM
