Anybody changed the cam chain on the 1.8t?
I have never seen the chain being replaced but we have replaced enough of the tensioners ushally for a leaking issue though If it is tapping to muck I would suspect the pump is on its way out we all know thta oil pick up screen is to small and gets clogged up to easily
ORIGINAL: brrman
you don;t wanna change your own cam chain unless you know what your doing - seriously.
Seconded, it's not an easy job.
Book it's 3.5 hours, so for an amateur mechanic that's 5 hours, and if you get it wrong you could screw the engine.
Searching through the forum for engine noise and came across this one. As I understand this post the cam chain tensioner is operated by oil pressure. Correct? Can this get clogged or does it just wear out? My engine has become noticeably noisier since I bought it 10,000 miles ago and I'm trying to figure it out. Car now has 110,000 miles on it. I'm changing the oil tonight but knowing my luck something that simple won't fix it but it has to be done.
It's a program AUDI uses for ordering parts. (I have it also hehehe)
ORIGINAL: rnbguy
howd u get that diagram above? is there a service manual for the audi a4? 1995?
tofast2belast
Dec 26, 2013 04:19 PM
Mlaubach
Aug 20, 2008 01:38 PM
