Anybody changed the cam chain on the 1.8t?
Old Feb 24, 2005 | 12:37 PM
clconversion's Avatar
Default RE: Anybody changed the cam chain on the 1.8t?
I have never seen the chain being replaced but we have replaced enough of the tensioners ushally for a leaking issue though If it is tapping to muck I would suspect the pump is on its way out we all know thta oil pick up screen is to small and gets clogged up to easily
Old Feb 25, 2005 | 05:33 PM
jblum's Avatar
How much is that going to run me if I take it to a mechanic vs doing it myself (can I even do this myself?)
Old Feb 25, 2005 | 06:38 PM
brrman's Avatar
you don;t wanna change your own cam chain unless you know what your doing - seriously.
Old Feb 26, 2005 | 12:43 AM
PaulA4's Avatar
ORIGINAL: brrman
Seconded, it's not an easy job.
Book it's 3.5 hours, so for an amateur mechanic that's 5 hours, and if you get it wrong you could screw the engine.
Old May 31, 2006 | 01:09 PM
truckjunky87's Avatar
Searching through the forum for engine noise and came across this one. As I understand this post the cam chain tensioner is operated by oil pressure. Correct? Can this get clogged or does it just wear out? My engine has become noticeably noisier since I bought it 10,000 miles ago and I'm trying to figure it out. Car now has 110,000 miles on it. I'm changing the oil tonight but knowing my luck something that simple won't fix it but it has to be done.
Old May 31, 2006 | 01:23 PM
Dj Spiel's Avatar
It's a program AUDI uses for ordering parts. (I have it also hehehe)
ORIGINAL: rnbguy
howd u get that diagram above? is there a service manual for the audi a4? 1995?
Old May 31, 2006 | 01:42 PM
techbod's Avatar
use 0W/40 full synthetic oil and change the oil filter, DJ don't keep your info secret
Old May 31, 2006 | 03:57 PM
  #18
Trey25's Avatar
Hey where did you guys get the parts manuals from? Can it be downloaded or its all on CDs that have to be bought?
tofast2belast
Dec 26, 2013 04:19 PM
Msnickbroderick
Jun 19, 2011 03:15 AM
Mlaubach
Aug 20, 2008 01:38 PM
keko2004
Oct 12, 2006 11:21 PM
classic079
Apr 26, 2006 09:45 PM
