Balance...
Old Aug 8, 2006 | 03:25 AM
jliu's Avatar
Default Balance...
I measured the spare tire in the trunk, it weights at 21.5 KG = 47.4 lb. Once I take it out from the trunk to reduce weight, my only question is will it change the balance of my car, especially in turning...
Old Aug 8, 2006 | 03:59 AM
Trey25's Avatar
Default RE: Balance...
In short...nope.
Old Aug 8, 2006 | 04:13 AM
jliu's Avatar
Bro, by short you mean short distance...or time. My concern is when I reach in certain speed and while turning will it cause a spin due the the weight balance...tks
Old Aug 8, 2006 | 04:44 AM
Trey25's Avatar
Audis are relatively heavy cars, losing 47lbs from the rear isn't gonna drastically change its weight distribution. Its already front end heavy and the suspension is designed for that. So you'll get the typical understeer but no drastic oversteer at speeds. If anything removing weight from the front end would change the ride characterics. You might see a little better gas mileage but thats about it. The only way I see it would affect the ride is in snow where you would want that extra weight there to act as "downforce" so you get better traction.
Old Aug 8, 2006 | 05:01 AM
jliu's Avatar
Thanks bro, in that case I'll take it out untill I'm going somewhere far or during snow...
DanaB6
Oct 11, 2012 10:10 AM
a12gaugehug
Apr 20, 2009 07:30 AM
jasondmaguire
Jul 25, 2008 12:01 AM
machineman
Mar 17, 2008 04:40 PM
tm2131
Feb 15, 2008 11:47 AM
