Basic A4 maintenance
Old Jul 13, 2004 | 03:57 PM
uomoa4's Avatar
Default Basic A4 maintenance
Hi, I went through the welcome forum, but I guess I need something even more basic than that.
As I wrote I bought my A4-1.8Ti with 84.000 miles on it, it's the 2000 model, Tiptronic
(that is great)
Anyway here's my list of Q.
A) What should I change (water pump? Transmission Fluid? what else?)
B) A good book-manual about (Audi) car maintenance
C) Basic toolset to be able to keep your car running
D) are those engine cleaners fluid any good?
E) Cheapest way to reprogram a key I intend to buy on Ebay? ( the dealer asked $160 to reprogram it)
Thanks!
Thanks!
Old Jul 13, 2004 | 05:23 PM
ImolaS4's Avatar
Default RE: Basic A4 maintenance
A) if they haven't been done: Timing belt, water pump, fuel pump, fuel filter, tranny fluid.
B) Bentley's manual on CD
C) I guess that's a question. Yes, get a good set at a reputable store; it should have metric and SAE sockets and wrenches, torx bits,and allen wrenches.
D) If you are referring to the stuff you add to the gas tank: NO! They are too corrosive. If you are referring to cleaning the engine bay: get Simple Green.
E) You will need another key that already works. Then you will use both to re-program the new key. There are a few tech articles on AudiWorld that you can read.
Here are two tech articles from AudiWorld
Article 2000
Resynching
Old Jul 13, 2004 | 06:05 PM
uomoa4's Avatar
Great Info! Thanks Imola. I'll do a google on the Bentley manual
ORIGINAL: imolas4
Article 2000
Resynching
Old Jul 13, 2004 | 06:28 PM
brrman's Avatar
If you are talkig about injector cleaner, Techron is generally accepted as a decent one. But if you use premium gas constantly, you should rarely (if ever) have to use it. They are, like Imola says, corrosive and can have a negative effect on your internals if used often or not in the correct mix with fuel.
You can use an engine cleaner to clean the engine if you like - Gunk makes one. I've used them and they are not harmful. Lots of people use Simple Green though. It works pretty well.
sumitcan
Jan 5, 2008 11:48 AM
coma
Oct 8, 2006 07:22 PM
///A4
Sep 20, 2005 01:29 AM
i3uddha
Sep 11, 2005 12:39 AM
AudiJapan
Apr 14, 2003 08:54 PM
