The Best Airbox Mod? writeup with pics..
Old Sep 11, 2006 | 10:12 PM
  #301
AudiCross's Avatar
Default RE: The Best Airbox Mod? writeup with pics..
But whaty i dont get is that it holds boost fine. goes right p to 18 psi, and i dont have a problem
Old Sep 12, 2006 | 12:18 PM
  #302
smokeU's Avatar
yeah check the L hose. I had same symptoms. I had most of my boost but not all. that hose is a culprit for having a tear in the corner that is not noticable until under boost it opens up and lets a lot of air pass through. check it out.
Old Sep 12, 2006 | 10:32 PM
  #303
AudiCross's Avatar
is that one form on top or bottom of the intercooler
Old Sep 13, 2006 | 05:35 PM
  #304
smokeU's Avatar
no it doesnt go to the intercooler. its a vac line that goes around/under the top right corner of the exhaust manifold. it has a breather valve on one end and the other end goes right into the manifold. if you look from the front of the bay it looks like the number 7. $15 w/ clamps at the stealer.
Old Sep 13, 2006 | 11:40 PM
  #305
AudiCross's Avatar
Err, do you mean the host that runs directally from the airbox to the turbo? and also, the sound comes from the tront left side of the car, from the intercooler side
Old Sep 14, 2006 | 02:10 AM
  #306
ADubyaD's Avatar
SoCal Crew Member
this mod owns, do it!!
Old Sep 14, 2006 | 01:16 PM
  #307
smokeU's Avatar
ORIGINAL: AudiCross
my bad I said exhaust manifold when I meant intake mani. its a really little hose about an inch in diameter. look at the manifold to the right of the engine. then look just to the rear of it. theres a black hose there that looks like a 7 inspect the spot where it bends.
if thats not torn I would say check all of your hoses leading to and from the intercooler which I'm sure you have. also look all around the intake mani theres tons of spot for a vac leak near all of those vac lines make sure they are all connected and clamped.
sorry about the confusion.
Old Sep 14, 2006 | 11:06 PM
  #308
AudiCross's Avatar
awesome, thanks smokeU
i found the leak, and since i dont have an extra lieing around, in wrapped it in electrical tape and zipties it for a temporary fix. and WOW. its insain....since i bought this car, it made this annoying noise. and its gone all the sudden. i hear my engine and exaust finally!
thanks
Old Sep 15, 2006 | 11:12 AM
  #309
smokeU's Avatar
oh good to hear bro! glad I could help. for so long I was wondering why I was still holding 15 psi but my car was soo slow. And I could hear a woooooooooosh under boost from the front left side of the engine (I thought intercooler also) till finally I spent some time looking under the hood when I saw the crack in the corner of the L hose... I was like hmmmm I wonder what this does. so I asked someone on here and they told me that was the culprit. went to the stealer that day and noticed now they sell those hoses reinforced (probly for a reason). I changed it that day on a hot engine (DOH) ten minutes and a couple burns later and I had my boost back.. no woooshing and my car was fast again! its a goood feeliing.
Old Sep 15, 2006 | 11:07 PM
  #310
AudiCross's Avatar
ya, the pulsing stopped, and it pulls a lot harder through the range. lol, after i fixxed that first, i didnt have enough xip ties, and i went for as test run and it started leaking again, so frusterated, i dove right in weith a hand full of zipties and electrikcal tape...without concidering the temperature of the engine
