The Best Airbox Mod? writeup with pics..
Old May 18, 2006 | 08:27 PM
  #201
Beer Mod's Avatar
Default RE: The Best Airbox Mod? writeup with pics..
The asshat that said he failed inspection is a dumbshit! He never failed because of this mod he needs to crawl back over here and say he's sorry [:@] stupidshit [X(]
Old May 19, 2006 | 06:22 AM
  #202
melange_not_tan's Avatar
haha sorry
Old May 19, 2006 | 01:28 PM
  #203
theycallmedalgo's Avatar
wouldnt a cold air intake work better than this mod seeing as how the whole filter will be sucking in cold air not just from a few holes? plus i dont think it would cause hydrolock but everyone seems to say you'll lose hp with an intake what is the deal with that?! and i tried using the search it wasnt working for me
Old May 19, 2006 | 03:21 PM
  #204
A4 the Quattro's Avatar
no a cold air wouldnt work better.. UNLESS.. you custom designed an awesome heatshield for your intake.. the problem with intakes is that they are only sucking in the hot air from the turbo.. which is no good.. and if you get a cold air intake with a long *** tube.. all the friction caused by air plumbing through an aluminum tube just heats the air up.. so then again.. no good..
the design of audi's intake system being so close to the turbo sucks for aftermarket intakes.. the stock box design is the superior design at the moment.. like i said .. unless you can fabricate some amazing heatshield to guard your intake..
Old May 20, 2006 | 02:55 AM
  #205
so i think a few of us are confused here. why would this mod be bad for 2.8 and/or only for 1.8T?
Old May 20, 2006 | 05:28 AM
  #206
BadLuckAudi's Avatar
its not bad for the 2.8 but better for the 1.8 cuz the turbo needs to get the more flow where the 2.8 dos just fine, the 2.8 you can just get an intake cuz you will anyway since thats about the only mod you can do to it
Old May 20, 2006 | 01:27 PM
  #207
Beer Mod's Avatar
Plus the 2.8 has less heat under the hood due to the lack of a 1000* turbo next to the intake....
Old May 22, 2006 | 03:33 PM
  #208
ok. thanks guys.
Old May 30, 2006 | 11:49 AM
  #209
00A41.8Quattro's Avatar
Carbonio makes an awesome setup for an airbox if you want to go that way. Well worth the $350 I spent.
Old May 30, 2006 | 06:32 PM
  #210
Beer Mod's Avatar
350.00$ !!!!!!!!!!!!!!!!!!!!! I spent 3.50$ bwwwwaaahhhhhhaaahhhhhh
