Big Brake Advice
Old Oct 31, 2007 | 08:39 PM
TheJazz7's Avatar
Default RE: Big Brake Advice
Doesn't work that way in terms of the parts...and you can buy arear brake kit,if you must, but it would be a waste of money. You do not need to upgrade your rear brakes, period.Has nothing to do with keeping the car "balanced." All carsare biasedto have more braking power up front than in the rear...you're not going to throw anything out of whack byadding a bit more braking powerto thefrontof astock car (which I'm guessing yours is).
Old Nov 1, 2007 | 01:02 AM
ggoodling's Avatar
balanced as in looks not performance. I can read what Cincy writes just as well as you can.
Old Nov 2, 2007 | 03:15 AM
pyropenguin's Avatar
ORIGINAL: ggoodling
so i can't do anything for the rears? that sucks. i mean even just to keep the car more balanced. seems like i should be able to do something with my left over front parts.
Sure you can.
http://www.034motorsport.com/product...oducts_id=1170
It's REALLY not worth it unless you're doing lots of racing (on a roadcourse that loves to give you brake fade).
Just get some nice pads, SS lines, and the a8 upgrade in the front.
Old Nov 2, 2007 | 12:23 PM
cincyTT's Avatar
I'm make believe
I thought this was very well put.....
ORIGINAL: TheJazz7
Unless you get your so desired 2.7T swap and rs4/6 upgrade.... THEN you can look into upgrading the rears along with the fronts. Increasing the fronts will make a much larger improvement than increasing the rears. With big fronts and with stock vs big rears, your probably only looking at < 1' of stopping length for the hundreds spent.
archaeic_bloke
Aug 1, 2011 01:00 PM
rawdney88
May 22, 2011 01:31 AM
AudiTTS
Mar 2, 2009 03:51 PM
cu52
Jan 26, 2009 03:31 AM
psuA4
May 19, 2008 03:28 PM
