blew up my cv joint
Old Aug 27, 2007 | 12:28 AM
oneg's Avatar
Default blew up my cv joint
So i had my car laid up replacing the front end
got all this together, threw some ceramics in, droped it, finished torqueing, and looked at the tire as i put it back on. It was hitting the tie rod end. so im thinking, ****.... do i need a rack?
then la de da... after some tooling around i pull out the half shaft and the bearing housing for the cv joint is destroyed. bearings and peices were falling out as i was removing it. so i just orderd the whole axle, new boots and all and should be done with it.
ran about 100$ for it.
so to any one out there who finds there tire rather close to the tie rod ( tilted in towards the engine), i would recomend checking you cv.
lesson learned and passed on.
Old Aug 27, 2007 | 12:32 AM
kriptonik's Avatar
Default RE: blew up my cv joint
Does it drive a lot better now?
Old Aug 27, 2007 | 01:07 AM
oneg's Avatar
with the whole front end kit done it drove much better, steering was so much tighter.
and i thought it was amazing before...
jinsojoo
Nov 11, 2009 05:59 PM
nycsweetestt
Nov 7, 2007 07:27 AM
Noobinator
Jun 30, 2007 04:30 PM
slowdownabhi
May 22, 2006 06:51 PM
dhourihane
Apr 4, 2006 02:05 AM
