boost gauges
you want one with Vac also.
Vac will tell you how well your car is in vacuum when not accelerating/under boost (which is your psi).
It can tell you if you have a leak under vacuum.
A vac/boost guage is only a few dollars more than a boost gauge - well worth the extra $$.
Like brrman said, when you accelerate, you make boost (psi or bar). When you decelerate, you make vacuum (inches Hg).
You could have a leak in either direction.
I currently have a vac leak and it is driving me nuts.
I was picking around at the vacuum system last night and found a small crack in a hose leading from my n75 valve.
This morning I can't get any more than 5 psi. LOL - checked the vag on the way to work and realized I didn't plug the
n75 valve back in (N75 open circuit code)
oooo ok i get it now i had a feeling that was how it worked im on my way out to get an auto meter as soon as i take a shower ...... hopefully it is a decent one ..... welll thanks guys
