Boost issues:
Old Nov 26, 2006 | 07:39 AM
  #21
jayson161's Avatar
Default RE: Boost issues:
i really do not want to believe this, i so do not have the money to buy a new turbo will it hurt the car running with a bad turbo for awhile or should i be hitting the bank for a loan real quick? haha
ORIGINAL: m5racer
ALL i have to say is i went threw the same **** as ur going through. did a proper pressure test no leaks, but the n75 nothing changed the dv nothing i did everything i could and i couldent figure it out. i would boost at 20 settle at 15-16 adn then at liek 4 k it would drop off to about 10psi............................................. .................................................. .......................... all of that equals the turbo is about to BLOW!!!!!!!!!!!!!. i know you dont want to believe it but most likely if u tired every possibility and noting will fix it your turbo will go (the seels and gaskets not the whole turbo) so if nothing works figure out what ur gonna do
Old Nov 26, 2006 | 04:58 PM
  #22
AudiCross's Avatar
you are running the stage 3 turbo, arnt you? what do you normally bosot with that and what r u boosting now?
Old Nov 26, 2006 | 06:10 PM
  #23
tooxtreme8813's Avatar
i dont think you can rebuild a gt series turbo
Old Nov 27, 2006 | 03:35 AM
  #24
jayson161's Avatar
i wasnt even boosting that much to start with. the previous owner had it set around 12-14psi and it peaked about 20psi. so now when i step on the gas the boost will spike and then drop back down to normal. i just looked on a few sites and a new GT25R is around $1k. I am so hating life right now.
Old Nov 27, 2006 | 03:43 AM
  #25
AudiCross's Avatar
waittt..what turbo does apr stage 3 run?
Old Nov 27, 2006 | 03:58 AM
  #26
jayson161's Avatar
well mine is a GT25R, im not sure if you can select a different size when you order the kit but that is the one my friend got.
Old Nov 27, 2006 | 04:12 AM
  #27
AudiCross's Avatar
Hm, okay. maby ur turbo is going. maby you ahve DV issues. who knows. lets hope its not going ;-)
Old Nov 27, 2006 | 04:19 AM
  #28
jayson161's Avatar
im really hoping its not going haha, ive already swapped my dv and n75 back to stock and havent fixed it yet. im going to try new hoses first and then proceed to shooting myself if i blew up my turbo
Old Nov 27, 2006 | 04:25 AM
  #29
AudiCross's Avatar
lol, good luck
Old Nov 27, 2006 | 02:47 PM
  #30
jayson161's Avatar
oh yeah btw does anyone have a part number for that hose?
