boost problems 2000 a4 1.8t
2000 a4 1.8t
My clutch is worn to the bone, and my boost is of the hook on rpm's!Im barley getting power to the wheels every boost. any one have info....
im going to replace the clutch so duh thats important but has anyone had similar problems with the clutch relating to the boost???
sounds like you are slipping pretty bad....I can think of two options...
If you have the $, replace the clutch asap, honestly, it's not worth letting it go till you end up stranded on the side of the road...
if you don't have the $, you could get a manual boost controller and turn the boost down (or if you are chipped try turning it back to stock)
gl!
gl!
