boost problems 2000 a4 1.8t
Old Dec 8, 2007 | 12:21 AM
marshalllichtenstein's Avatar
Default boost problems 2000 a4 1.8t
2000 a4 1.8t
My clutch is worn to the bone, and my boost is of the hook on rpm's!Im barley getting power to the wheels every boost. any one have info....
im going to replace the clutch so duh thats important but has anyone had similar problems with the clutch relating to the boost???
Old Dec 8, 2007 | 12:26 AM
Audi_Skydiver's Avatar
Default RE: boost problems 2000 a4 1.8t
Well since your clutch sends your power to your wheels then if it's slipping bad, which it probably is, you won't feel any power. Do you have a boost gauge?
Josh
Old Dec 8, 2007 | 02:02 AM
qUaTtRoA4's Avatar
sounds like you are slipping pretty bad....I can think of two options...
If you have the $, replace the clutch asap, honestly, it's not worth letting it go till you end up stranded on the side of the road...
if you don't have the $, you could get a manual boost controller and turn the boost down (or if you are chipped try turning it back to stock)
gl!
CruzGa1993
Apr 30, 2014 04:00 PM
craigt80
Oct 5, 2013 12:37 PM
laughatbilly
B7 Models
Jul 7, 2011 03:13 PM
thatA4guy
Apr 12, 2010 03:29 PM
odroggy
May 9, 2007 05:44 AM
