broken axel?
Old Oct 10, 2006 | 02:21 PM
96A4QuattroGuy's Avatar
Default broken axel?
I honestly dont know much about my car at all, so if this is a stupid question then go ahead and flame lol. Anyway, I'm not sure but I think my back right axel could be broken. When I am driving and then let off of the clutch, a sound that reminds me of metal hitting metal comes from that direction. Could my axel be broken or could it be something different entirely?
Thanks
-Dom
BTW as my name says I drive a 1996 A4 Quattro
Old Oct 10, 2006 | 02:58 PM
The Bishop's Avatar
Default RE: broken axel?
Jack only that wheel up and try to spin it. If it spins then you have a problem, If you can't spin it the axle isn't your problem.
Old Oct 10, 2006 | 06:17 PM
thanks!
Old Oct 10, 2006 | 06:29 PM
BadLuckAudi's Avatar
might just be a bad bearing
Old Oct 10, 2006 | 11:34 PM
TDRILL's Avatar
Wow if the axle was broken I think you would KNOW. It wouldn't make sounds only when you let off the clutch.
Get on your back and check out both rears. Look at the axle, look at the boots on either end of the axle. Look for any splattered fluid.
No matter what, it doesn't sound like you are one to jump under there and fix it. Get her over to a good Audi shop to get it fixed up. Post back what the problem was.
Old Oct 14, 2006 | 02:18 PM
dankhound's Avatar
It sounds more like the coast side of the rear differential gears is worn. Check your rear differential fluid and make sure its not low.
Old Oct 14, 2006 | 02:21 PM
CRAZYHAWK's Avatar
Could also be a CV joint.
copper07
Aug 7, 2012 09:24 PM
derZeck
Feb 22, 2012 02:53 PM
BroBrad21
Oct 21, 2010 03:40 PM
mxjess
Nov 17, 2008 03:50 PM
sheil
Jun 30, 2008 12:24 PM
