BT logs, timing issues
Old Dec 4, 2007 | 03:42 PM
cincyTT's Avatar
I'm make believe
Default RE: BT logs, timing issues
Just install the precision ic and see where it goes from there. You get the 350hp core?
Old Dec 4, 2007 | 06:53 PM
gotaudi's Avatar
ORIGINAL: cincyTT
I do not think it is a heat issue, it is probably playing a small role in the equation. I got the 350hp core (is this going to be big enough????)
here is the whole scoop:
-I am pulling loads of timing, on and off boost, hot or cold ambient air, 91 octane or 100 octane. doesnt matter
-My fuel trims are as followed:
idle: +1.8%
part throttle 24.2%
no cel thrown
- the A/F ratio is right on spec, doesnt indicate me running lean.
- Peak MAF rate is 185g/s with a vr6 MAF and a new stock sensor. unitronics states it should be well over 200g/s while in boost.
-when I unplug the MAF sensor the fuel trims go down a lot.
what do you think about that????
Old Dec 4, 2007 | 07:10 PM
cincyTT's Avatar
I'm make believe
you have a wbo2, run the a/f ratio. Plus i think if you cross 200 g/s, your housing is to small. So in this case you should be fine. The 350hp core should be plenty for your car.
Run boost, timing, and a/f log and we can graph it and see.
Old Dec 4, 2007 | 07:37 PM
gotaudi's Avatar
I do not have a wideband except for the stock wideband sensor that you get from vag-com. so do you want me to log blocks 20 (timing corrections), 115 (boost), and 31 (A/F ratio). I will try to get that as soon as possible for you.
thanks
Old Dec 5, 2007 | 02:42 PM
gotaudi's Avatar
Here is a log of blocks 31 (A/F ratio), 115 (boost), and 20 (timing corrections).
http://spreadsheets.google.com/pub?k...lVUOHGFefy87Ow
let me know if you sould likr to see anything else
bump for help
rabeye314
Apr 2, 2013 08:54 PM
Rn3037
Apr 21, 2010 09:26 AM
_zero
Dec 9, 2009 05:21 PM
Audi_Skydiver
Aug 5, 2008 05:17 PM
keninmi
Aug 21, 2006 06:38 PM
