Calling the masters..I am stumped on this problem??
ORIGINAL: acetrebo
well, if you have a blown head gasket, that would leak coolant, and the loss of pressure in the cylinder could cause the symptoms you are having. Check your oil and see if it looks like there is a milky substance in it. If so, you probably have a blown head gasket. Not too bad of a fix, but if you have coolant dripping down the block, that could be it. (unless you meant it was coming from the pump you mentiuoned)
Take a closer look at that leak and see where its originating from, and check the oil. Also the exhaust will smell different and be very white and thicker than usual.
ORIGINAL: CRAZYHAWK
Try disconnecting the MAF, to see if the problem gets worse.
MAFs go bad around 85K mi.
Also I am thinking maybe it could have something to do with the TC? at this point I am ether thinking about wasting more loot to make my ride drive like the day I got her or trade in and take a big loss on the deal for I owe about whats its worth so...ether way I am going to lose.
coolant leak could be coming from the intake manifold gasket ( the intake is also cooled ) and it could be a related problem with the TB which is also cooled by the coolant, just a thought
ORIGINAL: avant80@2.6
How did the plugs look when you changed them?
When was the last time the fuel filter was changed?
Have you disconnected the MAF to see if the stumbling stops?
My thought is something is dirty and only showing problems at low air velocity.
It's not enough to throw a cel.
But it's totally weird that you don't have any stored codes.
It would not hurt to throw some Redline SL1 fuel injection cleaner in there.
ORIGINAL: 2k S4
high pitch whine before I crank the motor over? sounds like the secondary air injection kicking in rather than the TB setting up saying that any coolant lose in that area is a concern and should be fixed
