CAR ALARM
Old Aug 6, 2007 | 04:40 PM
akoby9's Avatar
Default CAR ALARM
A friend of mine is having a problem with his alarm, please help....
I left my lights on in copper over night and when I went to unlock my car with the remote it didn’t work. Turns out the battery was dead, so I charged the battery all the way and tried to use my remote key again but it still is not working. Not only that my alarm seems to go off every time I open the door or start my car or anything like that. So I basically cant drive my car without the alarm going off the entire time as I drive down the road. How do I fix this?
Old Aug 7, 2007 | 05:13 PM
akoby9's Avatar
Default RE: CAR ALARM
anyone?
Old Aug 8, 2007 | 03:55 AM
kraylon's Avatar
is it an audi? maybe the remote need to be reprogramed if it is the factory alarm if it is an aftermarket it may of poped a fuse when he hooked up the battery charger
Old Aug 8, 2007 | 06:37 AM
99A4NOW's Avatar
If it is factory Audi it should disarm when you unlock the door with the key, so I'm betting it's not factory. In that case he needs to find out what kind of alarm it is, then read the owner's manual for it and see if it has a valet mode. Typically there is a switch of some sort that needs to be "flipped" or "pressed" while the ignition is turned on. Valet mode will allow him to either completly disarm the system or at least give him time to get in each time turn the key on and press the button to disarm it.
The description of the problem is still to vague to help out much more than that. It's like saying "my car is broke, how much is it going to cost to fix it?"
Old Aug 10, 2007 | 03:40 PM
akoby9's Avatar
just found out its a DEI alram, does this help at all?
huggybearv1
Mar 29, 2011 05:16 PM
debby
May 1, 2010 07:34 PM
rplets15
Dec 28, 2009 10:45 AM
batanguenio
Sep 26, 2006 07:07 AM
Art
Jul 17, 2005 12:21 PM
