car burns oil
Old Dec 17, 2007 | 11:11 PM
AudimaniaA4's Avatar
Default RE: car burns oil
Thanks for your input cincyTT. I'm not sure where the oil is going. I do get some white smoke off the tail pipe initially, when I start the engine. The car also emits whie smoke at a drive thru in cold temputers after drivng for a little while. Should that be a sign for concern? It does not blow white smoke when the car is wormed up and idling.
Old Dec 17, 2007 | 11:12 PM
onepoint8tee's Avatar
My idea of "recent" is weeks/hundreds of miles. Not months/thousands of miles. But anyway.................. If youre not using fullsynthetic, make the switch. None of that semi synthetic crap.A little white smoke on a coldstartup is nothing to worry about, especially in colder temps.
Old Dec 17, 2007 | 11:20 PM
I bought the car with 63000 thousand miles on it. I changed the oil when I got the car. I am now at 66000 and I am ready to change it again. I use Mobil One synthetic oil. I am thinking of adding a oil treatment (CD2) to the car in my next oil change. Next best thing to nothing. Hopefully it will help, although I doubt it.
Old Dec 17, 2007 | 11:24 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: AudimaniaA4
sounds like you have some rings that are going bad. Get a compression tester and follow the how to on top of the forum
Old Dec 18, 2007 | 03:09 PM
FortyCal's Avatar
my car 2.8 eats over a qt between 3k miles oil changes. i get it changed locally however, so they top it off the mobil 1 synthetic free. my car has been drinking oil like this for all 40k miles i have owned it. never seems to be a problem, no leak i know of, you just have to stay up on checking your oil level often + carry some extra qts with you
Old Dec 18, 2007 | 03:18 PM
techbod's Avatar
its normal ie:- 1 liter per 1,000 miles ( depending on weather conditions ) information from dealers,
4.6 liters to a gallon UK,
4 quarts USA,
so 1 quart over 5k miles is extreamly good ( approx oil change times )
Old Dec 18, 2007 | 03:22 PM
ssbaudi's Avatar
i lost 2.5 quarts in 1990 miles... i know how it feels
Old Dec 18, 2007 | 03:23 PM
  #18
dombombBMX's Avatar
thats some interesting stuff there techbod.....
that should answer your questions about burning a little oil...
I was lossing oil for a while about a little more than a quart inbetween changes.... but come to find out it was a bad oil pan gasket...
so if its excessive take a look around
Old Dec 19, 2007 | 12:12 AM
  #19
Thank you all so much for your positive feedback. I feel allot more comfortable knowing that it is not unusuall for my car to burn oil. I no longer feel like it's neccessary for me to rush to the nearest mechanic. Although, I feel as though I should get it checked out when convenient.
alexmurphy
Oct 5, 2010 05:00 PM
Stanmarsh
Feb 9, 2010 10:59 PM
grytsenko
Nov 6, 2007 08:04 PM
elphlako
Jul 30, 2006 07:36 PM
